My Alba (Model TVD 3402) has broken down. When switched on, it goes on standby mode and i cannot get a picture, the dvd draw is still opening/closing .... can it be fixed and if so at what cost?
SOURCE: alba 3406 tvd
Connect pin 1 & 5 together (momentarily with a small switch), on the remote control handset. with the tv already switched on, This will put the set into the engineering set up mode. You can step between the various options by using the -/-- button. the Mute button invites you to save your changes which I believe is saved when you next press the -/-- button. there are 18 different service pages in all, be very careful not to change things which should be left alone, as this menu controls the way this set operates. The menu button exits the service menu. I believe menu 13 should be the AV-SND options menu, you can select either DK-I-BG or M sound systems. only set one system to "on"at any one time. You may also need to check 14, the C- SYSTEM options Menu. Good Luck, A D.
Posted on Apr 04, 2008
Junoon007
  • 1011 Answers
SOURCE: phillips 42 inch monitor 9932/0s1.
Dear Sir/madam,
Caused by failed capacitors. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment.
thanks
good luck
Posted on Aug 25, 2008
SOURCE: Memorex DVD player won't work
the standby light switch is your on/off switch as well......
Posted on Nov 28, 2008
Gurudristi
  • 98 Answers
SOURCE: The receiver goes on standby mode when volume is high
Your receiver is basically going into protect mode.
The SR 605 contains a microcomputer for signal processing and control functions. In an unlikely event, it may cause it to lock up. Unplug the power cord from the wall outlet, wait for 10 to15 seconds and then plug it back again.
Please also check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem. If you still can’t resolve the issue yourself, try resetting
the AV receiver/AV amplifier before going on to opening the Receiver.
To reset the Receiver to its factory defaults, turn it on and, while holding the [VCR/DVR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the Receiver will enter Standby mode. (note that resetting your receiver will delete your custom settings as well as your radio presets).
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck. Thanks for using FixYa!
Posted on Mar 13, 2009
  • 534 Answers
SOURCE: fujitsu power supply shutdown goes to standby mode. no picture. If I turn it off for a while I get great picture and after a while it shuts down and goes into standby mode. Is this a power supply that
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in the P42HHA10 model. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A similar Service Bulletin is probably available to suit your model. A competent service technician should be able to implement the service bulletin.
Posted on Jun 05, 2009
My Alba dvd player shows loadng but then goes back to open or close. It won't play.
Laser pickup unit fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 28, 2017 | Alba Televison & Video
Television will not stay on. Runs for 5 seconds then goes into standby mode.
Modern Flat Panel Televisions these days are really just computers inside. The Switch Mode power supply has the ability to sense faults & over current draw. So... there really isn't much the average person can do to fix an electronic problem.
The usual problem is overheating, bad connector problems & electrolytic capacitors leaking or popping. If you don't have the skills to open & look for problems then you will have to take it to a tv electronics guy.
Cheers
Feb 21, 2015 | Panasonic Televison & Video
Alba lcd42880f1080p
Could be a failing power supply
May 12, 2013 | Alba Televison & Video
Using an upgraded MC9090 gun...connexion broken in standby mode
This could be 2 thinks. First check to see if under your wireless profile that the card is set to CAM (Constantly Awake Mode). This doesn't help you battery life, but stops the radio card switch off and closing any open connections.
Next you could see what you power settings are. In control panel open up the power settings. You can change the time when the terminal goes into standby when running on battery power and also the CPU power mode.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL +44(0)1202 620955
May 05, 2010 | Zebra Symbol Technologies MC909X-G Series...
I was watching my kp61v80 and the screen went black-can you give me the trouble codes for the flashing standby light
Diagnosis item
TIMER/STANDBY
Indicater
Number of blinks
Supposed malfunction Condition
Self-diagnosis
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
circuit.
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Jun 17, 2009 | Televison & Video
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
The dvd draw will not open when I press the open/close button.
You can try reseting the unit.
Reset the set to the default factory settings:
All the information stored
(programmes, time and date) will be lost.
1.
Disconnect the set from power supply.
2. Press and hold down "STANDBY•ON" on the set and reconnect the set.
3. As soon as "IS TV ON?" is displayed, release "STANDBY•ON."
Hopefully reseting it will clear whatever problem it is having and allow you to once again use your DVD player.
Hope this helps. Good Luck.
Apr 08, 2008 | Philips LX9000R System
Alba 3450 tvd
some dvd players do not have the REGION CODE set until the1st disk is put in. The region then is set to that disks region.
Feb 16, 2008 | Alba DVD-108 DVD Player
Alba 3406 tvd
May 05, 2007 | Alba DVD-513 DVD Player
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
