Question about HP Office Equipment & Supplies
I have a c8100 all in one printer/scanner/copier The machine wont scan as it comes up with a message saying that the TMA tray is not located properly. I have been useing it to scan photo prints and it has worked ok,however, I tried to use the scanner for slides,but failed for the above reasons. I did notice that the menu i was useing for scanning the prints has now changed,to what appears to be a menu for scanning slides. I wouls appeciate some help please Regards Don Steer
Dear Sir/Madam
Thank you very much for your mail,I wont need the plan you offered,however I will tell you how I solved the problem.
I went into the HP solution centre,on the bottom right hand side of the menu list there is a spanner shown indicating settings.
I opened that item,pressed scan settings,there are various options available,these you can add of take away from the printer scan menu.
I added picture to mail & picture to file pressed OK,and they both appeared on the main printer menu.
The problem was solved,and the scanner worked correctly from that point.
Regards D.S.
Posted on Aug 14, 2008
SOURCE:
SCANNER DOESNT SCAN ALL OF THE IMAGE
If the scanner is connect to Surge protector, try connecting the scanner to wall outlet. Also turn off the scanner and Clean the Scanner glass with lint free cloth
Regards,
Seans
Feb 26, 2013 | HP LaserJet 3055 All-In-One Printer
TMA doesn't work ;code 22
If 22 is blinking in the Scanner LCDThe Transparent Materials Adapter (TMA) may be attached incorrectly or is broken.
  1. Disconnect the scanner power cord.
  2. Disconnect the TMA cord from the scanner.
  3. Verify there are no bent or broken pins in the cord plug of the TMA. If the cord has bent or broken pins, it will be necessary to contact HP .
  4. Reconnect the TMA cord to the scanner.
  5. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  6. Check that the TMA is properly positioned on the scanner glass; either reposition the TMA in the positioning plate or reposition the positioning plate on the scanner glass.
  7. Reconnect the power cord to the scanner.
  8. Attempt to scan.
If 22 "The scanner could not scan" displays on the screen and the Transparent Materials Adapter (TMA) is being used
  5. Reconnect the power cord to the scanner.
  6. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  7. Attempt to scan.
  8. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
If 22 "The Scanner could not scan" displays on the screen and the TMA is not being used
  1. Disconnect both the scanner power cord and the USB cable.
  2. Perform a self-test on the scanner if it has a built in self-test. Click here for instructions on performing a scanner self-test (c00030441) .
  3. If the scanner passes the self-test, reconnect the USB cable and attempt to scan. If the scanner fails the self-test, it will be necessary to contact HP.
  4. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
May 05, 2012 | HP 4570C Flatbed Scanner
How to unlock my M20i scanner
Release the lock, down the scanner is a tiny plastic piece between the oupt tray (the place where the paper goes out) and the top of the scanner
Fosg2000, Rate me please
Mar 16, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Scanner locked
check documentation for the exact location of the lock, usually located on the flatbed.
Sep 17, 2009 | Gestetner DSm515pfd Digital Copier -...
HP Photosmart C4580 wont scan
It seems that scanner glass is not glowing or may be bulb are not moving properly.
you can try these thigs:
1)Turn ON the printer unplug the powe cable from the back of the unit; wait for 30secs; replug the power cable.
2) Try this to check teh funtionality of hardware Load letter or A4, unused plain white paper into the input tray.
  1. Press and hold the Cancel (c01235250.gif ) and the Start Copy Color buttons at the same time.
  2. Release both buttons. The self-test page prints.
3) Now check if its copying or not?
It will work fine(if your printer scanner glass is fine)
You can also try scanning from computer(if installed)
the location of file would be=
c:\program files\hp\digital imaging\bin
here locate for file "hpqscnvw" hit it and try to scan
Best of luck
Jul 04, 2009 | HP Photosmart C4580 All-in-One InkJet...
I WANT TO KNOW THE MEAN OF ''ERROR 06'' IN HP SCANJET 8270 AND THE POSIBLE SOLUTIONS... THANKS
If LCD displays Error 06 or Error 09 , the TMA might require service
Press SCAN PICTUREc00068011.jpg button once (see Figure 3 above). The TMA lamp should turn on (see Figure 4 above). If pressed a second time, the TMA lamp turns off (if TMA is detected). NOTE: The scanner carriage lamp should be off when the TMA lamp is on and should be on when the TMA lamp is off. The only time the TMA could not be detected is if the accessory cable is not plugged into scanner
Jul 02, 2009 | Office Equipment & Supplies
Can't scan PLEASE HELP!
SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
  1. Load the slides or negatives in the TMA and place it on the scanner glass.
  2. Open Image Zone and click on Scan Picture to scan everything.
  3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
  4. Click on the first picture in the scan preview and make the following changes:
    • change the dust and scratch removal/sharpness to none
    • change the resolution to 72 dpi
  5. Click on the second picture in the scan preview and make the same changes described above.
  6. Click on the third picture and then the fourth picture and make the same changes.
  7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
I am looking for instructions on this product.
Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
Step 6: In the Scanning from dialog box, click Change Settings.
Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
Step 8: Under Scan To select Save to file. Then click Scan.
Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
May 01, 2009 | Office Equipment & Supplies
Canon MP780 wont scan
Download and reinstall scanner software and scan driver
Nov 01, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Open Questions:
159 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
