Question about Maytag Microwave Ovens
I didnt get bolts and togles to mount over the range micowave to wall. model # MMV5156AWW serial#10181154CE
  • Maytag Master
  • 9,098 Answers
You can download Maytag owner's manual and installation instructions here.
That will tell you the parts you'd need to order for installation.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 12, 2008
Uninstall Frigidaire FMV156EMA over range microwave?
If you have removed the bolts in the cabinet above, the unit is hanging down on the range. All you need to do is get a helper and lift the front edge a little bit and then lift the edge at the wall up about an inch and lift it off.
Mar 05, 2015 | Frigidaire Microwave Ovens
I have a white GoldStar Micowave the is mounted to the wall above my stove, Model # MV1526W. I need a front top vent cover for it. I am looking for the cheapest costing web site I can order on line. I...
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
Apr 03, 2011 | Microwave Ovens
How to uninstall a Whirlpool microwave Hood Combination? Model MH6600XV
Unplug the range and move it out of the way.
Open the cabinet above the microwave.
Unplug the power cord.
Remove the 2 bolts going through the cabinet into the top of the microwave.
Have a helper hold the microwave in place before these bolts are removed.
After the bolts are out,assist the helper by lowering the front of the MW and lift the back of it off the mounting bracket attached to the wall.
They are heavy and awkward.
A helper must be used.
Jan 21, 2011 | Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Look inside the cabinets to see if there are any screws, as they act as anchor support, in supplement to the mounting bracket at the back of the microwave which supports most of the weight.
Jan 21, 2009 | Whirlpool MH1150XM Convection/Microwave...
I have a double roper oven Model #39758B0 Serial # 8Roo896 Problem when turning the top oven on I get an F-5 signal and the oven does not turn on. I need to know how ro fix this problem. Thank you, Rita...
My problem is with a roper double wall oven not a micowave. When turning the top oven on I receive a F-5 signal and the oven does not turn on. I misplaced my manual hoping you can solve this problem or send me the manual.
Thank you,
Sep 16, 2008 | Roper MHE14XKB Microwave Oven
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
