Question about GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260 The locking mechanism does not appear to be sticking. The wash cycle starts normally, but will stop part way through.
  • 2 more comments
  • Anonymous Aug 25, 2008
    The door will not lock and the washer turns on but will not fill with water or start up, I can hear the motor running but nothing is happening. I pressed th power button and the washer stays on not doing anything.
  • Anonymous Oct 13, 2008
    My washer goes through the wash cycle then the door unlocks during the rinse cycle complete and will not comlete the wash. This has happened periodically since I bought the washer about three years ago. I have had it repaired twice, but nothing seemed to to be wrong with it when the repairman showed up.
  • Flybry Feb 16, 2009
    My door will not latch. The machine wiil turn on howver the door latch is broken and wont pull the door to seal it. It looks like an easy fix. I simply dont know how to remove the front pannel. I also have the dryer stacked on top of the washer. Can I remove the front pannel without unstacking the machines?
  • Joe Witte Feb 16, 2009
    we have the same issue. Our wash cycle will be interrupted in the middle of a cycle. We have to "re lock" or "restart" the washing machine- then it restarts. I cleaned the drain, to no avail. Any suggestions?
  • 725 Answers
Replace door lock
Posted on Nov 17, 2008
How do I get the door to open on a Maytag washer that remains locked?
It sounds like the timer is defective. You may need to call a Maytag sales and/or service center and ask them what to do. WIll the washer start a new cycle?? If so start a new cycle and swee if the machine will get past this sticking point next time.
Sep 08, 2014 | Washing Machines
I have a FE WCVH6260. Multiple times every cycle the machine door will unlock, and the cycle will stop. It will only restart when the "start/stop" button is pushed again.
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
Aug 11, 2008 | GE Washing Machines
WASHER MODEL WCVH6260 LOCK MODE
see this and fix it. God bless you
However go to instr .manual and read the section troubleshooting if you do not have it download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | GE WSXH208A Front Load Washer
Front Load wcvh6260 GE front load washer.
I dont think this is a problem with the motor or inverter board.
Check if there is a control device in the machine that is stopping the motor half way through the wash cycle
Apr 27, 2012 | Exercise & Fitness
GE WBVH5100HWW front load washer stops at 1
It appears that you have an electronic control board (directly behind the touchpad) issue. Contact an appliance service company.
Apr 13, 2010 | GE Washing Machines
Ge washer wcvh6260 ...... start/pause button flashes, won't start
Does the 'door locked' light come on? If not, check the switch and it's actuator (a pin that is part of the door latch).
Aug 22, 2009 | GE WCVH6260F Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
My 2 year old front load washer, model#WCVH6260, just stops while running, usually during spin but now during a rinse just as often. lights look normal but nothing happens. If I unplug it and wait a...
I think that you need a new control board if it is electronic if it is analog then it may be faulty wireing or since it is a front loader it may be a door sencer problem there are a number of reasons why you just need to find out which one
Hope it helps
Jul 09, 2008 | GE Washing Machines
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
345 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
