Question about Acer Aspire 3680 Laptop
How do I reset the memory modules and hard drive?
    Sergeant:
  • 324 Answers
To rest these items, simple remove each one and reinsert in the machine. Hope this helps.
Ron
Posted on Dec 09, 2008
  • 50 Answers
Go thru the recovery then follow the steps appeared on the screen..
Posted on Aug 28, 2008
No start, but power supply is good
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Jan 19, 2013 | Computers & Internet
I am having an issue with my Western Digital Caviar Green 1.5 TB 64MB Cache hard drive. Recently, I put my computer into stand by, and when I turned the computer back on the hard drive seemed to have
Check RAM
How many ram modules are in the computer either remove them or swap them always place the larger ram module closest the CPU central processing unit
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Hope this helps
Oct 30, 2012 | Western Digital WD Caviar Green WD15EARS -...
Makes a beeping sound when on
this is a memory module issue. take the the memory module and use pencil eraser and clean the metal strips of your memory module then put it back in to your computer then observe. if same issue will happen, then you have to buy new memory module.
Mar 27, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
17 inch monitor goes blank
  • Prepare to diagnose the computer .
    1. Disconnect all peripheral devices.
    2. Perform a Hard Reset.
    3. Disable the Automatic restart on system failure option.
  • Remove any non-system disc from the computer . During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
  • Reseat the memory modules . If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory. There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots. Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
  • Reset the BIOS to default condition . If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly. To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
  • Perform a memory self test . There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message. If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors. To run the memory test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
    • If the BIOS Diagnostics screen displays, select Memory Test .
  • Reseat the hard drive . If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive. If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook. Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
  • Test the hard drive . If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. To run the hard drive test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
    • If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
  • Feb 04, 2010 | X2Gen MG19MY 19" LCD Monitor
    How to open sony vaio-pcv-w101/w to replace bad ram?
    Try this:
    STEP 11
    Lift up and remove notebook display panel.
    13-taking-apart-notebook.jpg STEP 12
    Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
    14-taking-apart-notebook.jpg STEP 13
    Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
    15-taking-apart-notebook.jpg STEP 14
    Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
    Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
    Hope this Helps
    DR GEEK MD
    May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
    Operating system not found
    I probably meant to say "reseat" the memory. Just remove the memory module(s) and reinsert them in their slots. This problem can also sometimes be resolved by reseating the hard drive. I had this happen to me just the other night. The laptop slid off of my lap and fell to the floor. Just fell about a foot and a half, and didn't hit all that hard. Kinda partially caught it as it went. But the laptop didn't like it and I had a message of "Operating system not found". Reseating the hard drive had me up and running in about 30 seconds.
    Ron-
    Jun 22, 2008 | Acer Aspire 3680 Laptop
    Disassembly
    You didn't explain why you are taking it apart, but the two main reasons are Hard Disk drive Replacement
    & memory (RAM) Replacement
    The chassis of the computer is built sort of like the frame of a car
    so I will detail how to do the two operations below
    Hard Disk drive for 7510GX Laptop:
    1. Back up any data you want to transfer to the new hard drive.
    2. Before beginning, review electrostatic discharge (ESD) precautions.
    3. Shut down the computer, and then disconnect the power adapter.
    4. Disconnect the modem and network cables.
    5. Turn the computer over, and then remove the battery.
      1. Slide the battery lock to the unlock position.
      2. Slide the battery release latch.
      3. Lift the battery out of the bay.
    6. Remove the hard drive kit screw.
    7. Slide the hard drive kit out if the computer.
    8. If your new hard drive already includes the hard drive kit bracket, go to step 13. – OR –
    Adding or Replacing Memory Modules
    1. Shut down the computer, and then disconnect the power adapter and modem and network cables.
    2. Turn the computer over, and then remove the battery.
    3. Loosen the memory bay cover screw.
    4. Remove the memory bay cover.
    5. To remove a memory module, locate the two clips on each side of a memory module, and then slowly press outward on the two clips at the same until the module tilts upward.
    6. Pull the memory module out of the slot.
    7. Hold the new or replacement module at a 30-degree angle and press it into the empty memory slot. This module is keyed so that it can only be inserted in one direction. If the module does not fit, verify that the notch in the module lines up with the tab in the memory bay.
    8. Gently push down on the SO-DIMM and make sure that the two clips on each side of the SO–DIMM click into place.
    9. Replace the memory bay cover.
    10. Replace the memory bay cover screw.
    If you need to do something further, write back.
    I hope that helps :)
    TrustMe
    Apr 16, 2008 | Gateway 7510GX Notebook
    Laptop hp pavillion ze4300
    Probably bad memory or loose CPU module. First try removing and resetting CPU. You'll need to remove Keyboard, Palmrest, and heatsink and shield beneath Keyboard. You'll need a small Phillips screwdriver to remove screws and small standard size screwdriver to loosen screw holding CPU. After removal/reset, put everything back together and try powering back on. If still same problem, replace memory located on bottom of LT located behind door. Also, you may have a memory module located under Keyboard next to CPU that may be bad.
    Jan 06, 2008 | HP Pavilion ze4300 Notebook
    Toshiba satellite monitor problems
    Sounds like the memory module is bad. Return it or get a warranty replacement.
    Aug 14, 2007 | Toshiba Satellite Satellite 5200 Series 15...
    Acer Aspire 3680 Laptop Logo
    1,208 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
