Question about Gateway 7330GZ Notebook
Gateway 7330GZ PC Notebook screen going off and on
How do I get to screen cable, I have taken all the screws out of the back but the two parts will not come apart. Are there clips inside that I have to compress ???
I'm EE tech. for over 20 years
experience and this is driving crazy.
If this was not my wife's I would buy a new one.
Thanks CN
  • tjwatson59 Oct 28, 2008
    I have been building up the courage to take my son's apart to replace the video cable. It runs from the motherboard - up through the right side hinge and across the bottom of the screen inside the bezel. The part can be found online ( I found it on e-bay ) it is a ribbon cable with two 90 degree bends. I think almost everyone with this model is having this issue.
  • Anonymous Dec 08, 2008
    screen just goes black in certain positions -seems it is just bad contact
  • 44 Answers
Ya, my 7330GZ has been having this problem. I did end up taking the screen apart.
Removing the little black nubs around the screen allow you to remove the screws, then you just use a flat headed screw driver to unclip around the edges (some can be stubborn, especially along the bottom).
The screen is glued to the casing along the top and bottom, so you have to gently separate the two.
After you have it opened up the screen has 3-4 screws along the left and right side (the right side is a pain to unscrew since the wireless antenna casing runs right along it).
Once you remove those screws you can take the screen out and get access to the ribbon cable running along the back.
Posted on Dec 12, 2008
The momentary switch on my Gateway 7330GZ laptop is defective. If I can slide it to the proper location, it will work. How do I remove the display portion to access the screws to remove the top panel and...
Here is a video on how to open the monitor on a Gateway notebook, although if the switch isn't working anymore I assume there is a part of it broken inside and you might need a replacement.
Dec 07, 2010 | Gateway 7330GZ Notebook
I can get the bottom off of my Gateway 7330GZ laptop
have u checked under the rubber cushions also
Jun 28, 2009 | Gateway 7330GZ Notebook
I have taken all of the screws out of the bottom - it still won't open.
The case snaps together. Try pulling it apart. It is designed to NOT easily come apart, so you will have to gently work at it without breaking anything.
May 31, 2009 | Gateway 7330GZ Notebook
I have gateway 7330gz I can not open back (for cleaning)
Put all the screws back in except for two... on the bottom of the case the one directly above the "ew" in Gateway 7330 and the screw that is about 3 inches to the left of that sticker.. For further clarification, but not at the outside corners they're both near the back of the computer.
After those are removed, open the laptop with the screen completely open so the computer almost lays flat. Use a precision awl or flathead screw driver to pry up the strip at the top where your power and sound buttons are... I had the best luck prying it up from the left. Be careful about the ribbon cable that is under the buttons that goes to the motherboard... if detached it is difficult to reattach.
From there it should be pretty easy to see the 2 screws for the keyboard and then 4 screws on a metal plate which once removed will give you access to most of the motherboard.
Feb 17, 2009 | Gateway 7330GZ Notebook
Notebook Gateway 7330GZ won't boot
Hm...That sounds like either the motherboard is dying/dead or a device is (such as the hard drive). I would suggest removing one piece at a time and see if you can get past that screen. The most annoying would be if it is the DVD drive since it's probably the most difficult device to remove from the laptop. (If memory serves it involves removing a certain screw from the bottom and then getting under the keyboard so you can push it out).
Do you have a second stick of RAM installed? Mine died a while ago and caused real heck with my 7330GZ.
Nov 16, 2008 | Gateway 7330GZ Notebook
Dissassemble a gateway 7330 gz
well power button on the plastic or the real power button on the board??? have ya taken out the top plate off over the power button???
Nov 15, 2008 | Gateway 7330GZ Notebook
Power jack repalcement Gateway 7330GZ Notebook
you have options....#1 send it out to gateway for an arm and a leg...(i have the same model and had the same problem), #2 find a local computer repair store...they will most likely charge about 30 for the part.(that's what i was charged + 60 an hour for labor took 2 hours...) or #3 do it yourself, if you can solder then i can talk you through most of the dis you can get the part remarkably cheaper
Nov 08, 2008 | Gateway 7330GZ Notebook
Gateway 7330GZ laptop. Good battery, good Ac Cable will not turn on?
The system board on the laptop needs replacement.
Hope this helps :)
Nov 25, 2007 | Gateway 7330GZ Notebook
Screen problems
Try the power save options.
Nov 13, 2007 | Gateway 7330GZ Notebook
Gateway 7330GZ Notebook Logo
111 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
