Question about Cuisinart EM-200 Espresso Machine
No flow Sometimes there is no water flow through loaded portafilter; pressure builds; button light flashes. Sometimes it works fine. Can't figure out what I'm doing different when it doesn't work. Filter not seated properly? Too much/ too little coffee? Flow is OK without coffee in the filter. I had original machine replaced; same problem; must be me.
  • bjshil May 11, 2010
    Contract Web page messages "error on page." I can't see it.
  • 8,596 Answers
Tamp the coffee a little less - run water through filter basket to make sure it is dripping out before filling with espresso grounds. Dry the filter thoroughly before inserting coffee grounds. I would reccomend using double filter basket only instead of the single.
Posted on Dec 10, 2008
After successfully using the machine I tried to make a second coffee. Water continually poured into the tray and the machine sounded very loud (as if it was starting up). I then tried to shut down the...
The coffee grind is too fine, or you are tamping too hard, First remove the portafilter and press the brew button if water flows move on if not remove the shower and clean. Now that we have a nice flow of water without the portafilter. Now we will add coffee to the portafilter, and level it out, do not tamp and try to run a coffee, if that works then the Tamp is the problem, if you tamp and still have the problem then the grind is too fine.
Jan 02, 2011 | Breville BES820 Espresso Machine
I've tried grinds from a very fine to a coarser grind in my Rancilio Silvia, but the water is going through the portafilter/coffee too quickly. When I clean out the portafilter, there is too much dry...
Check the shower screen to make sure it is not damaged. Then try this get coffee ground from the store at #2, 3, 4 and 5 at least 1/4 pound each then use that to figure out what setting works best for your machine, also note the tamping pressure. Fill portafilter to rim then tamp to fill ring in basket.
Aug 24, 2010 | Rancilio Silvia Espresso Machine
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
Low water pressure, so takes ages to produce a cup of coffee. Has been de-scaled regular
If you get good flow with the portafilter out, you may need a new pump. When you descale do you run the descaler through the brew head? That is one problerm that people make is running the descaler through both the wand and the brew head. Sclae will build up in the pipe in the brew head and restrict it.
Feb 28, 2010 | FrancisFrancis! X1 Espresso Machine
I don't have enough water pressure to make cofee. Very little water comes out of the shower head. The shower head is clean, it is not plugged. I suspect it is the pump? Please advise
I had the same problem: clean showerhead, machine pumps hot water just fine, but very little brewhead flow. Descale made it worse but that was a big clue! I took apart the brewhead and found grains of scale in the boiler, like pulverized beach shell:
Some of those bits apparently made their way into the three way valve and clogged it. I could not blow air through the channel between the plunger and the boiler. Not surprising: the inlet hole inside the valve is TINY and clogs easily.a0bc8304-2405-4fdb-a444-21cf80e7701a.jpg
Once I got this part cleared up inside (and cleaned out the rest of the scale from my boiler so it didn't immediately re-clog!), my brew flow was restored.
Sep 05, 2009 | Gaggia Classic Espresso Machine
Espresso machine will not make Espresso.
Try this remove the portafilter and press the brew button, if water comes out of head, machine is fine but the grind or the tamping(packing pressue) used on the coffee is not right. If you are grinding the coffee just before using it, try a coarser setting. If you pre grind at the store then try tamping the coffee lighter.
May 29, 2009 | DeLonghi BAR 14 Espresso Machine
Espresso does not make
Remove the portafilter and press the brew button, if the water flows from the head with a nice flow then the problem is with the grind (too fine), or the coffee has been Tamp too hard.
If water barely flows when you press the button then try backwashing the machine and removing the shower screen to clean it.
May 19, 2009 | Coffee Makers & Espresso Machines
Waterflow/heat seems fine - but little/no extraction
Try running the gro;up without the portafilter in place, what does the water flowq look like: is it a nice strong flow or barely a dribble. If if is barely a dribble, backwash machine with purocaff and check shower screen, that may be clogged. If you have a nice flow then try adjusting the grind on the coffee grinder.
May 09, 2009 | Rancilio Silvia Espresso Machine
Saeco portafilter instructions
When using ground coffee, use coarser grind like the size of table salt grain. Feel the ground coffee for adjustment. Do not tamp, just level the cup with coffee grounds and lock the portafilter into the group ring. Pull the handle all the way to the right and hold. Turn espresso hot water switch on. Hold the portafilter pulled all the way to the right for 5 seconds (pre-infusion pressure builds up to 9 bars). Release the handle at the end of 5 seconds. Espresso shots should be max. 2-Oz. in the cup. For larger quantity, use two shots. For an Americano, add hot water instead of allowing 8-Oz. water to pump through the coffee grounds.
Mar 05, 2009 | Saeco Aroma - Stainless-Steel
Cuisinart EM-200 Espresso Machine Logo
923 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
