Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Reinstallition how do i reinstall the programs because its not even installing the data from my disc that came with the calculator??? (please give step-by-step instructions)
  • darkgalac11 Aug 11, 2008
    by programs i mean that my applications that were included when i got(just yesterday)T.T
    by the way just wondering why would they even make so you can clear EVERY bit of data without a backup?
    Scholar:
  • 132 Answers
First, turn it on. Once the calculator is on, press the "2ND" key (I believe it is a blue key in the ti-84 plus silver edition). Now press the plus key (+). A little above that key, you should see the word "mem." When you see the screen titled MEMORY, move the cursor all the way down to the option that says "Reset." From here, you can choose to reset either the RAM memory, or the factory settings. The factory settings are the "Defaults" option. I hope this helps.
Posted on Aug 16, 2008
TI84 does not work!
Perform a manual Garbage Collect.
  1. Press [2nd][0] to access (CATALOG)
  2. Press [TAN] to jump to first command that starts with G.
  3. Find GarbageCollect
  4. Press [ENTER][ENTER][2:Yes].Garbage collection may take up to 5 minutes
  5. After garbage collection is finished retry transfering data to calculator.
Uninstall and reinstall the TI-Connect software:
  1. Go to Start >> Settings >> Control Panel or Start >> Control Panel and select "Add or Remove Programs".
  2. Locate the TI-Connect software in the list and then choose "Remove".
  3. Once the software uninstall process has completed, please shut down and power off the computer.
  4. Wait approximately 20-30 seconds and then reboot into Windows.
  5. Download and install the latest version of the TI Connect software from the TI Connect Software home page.
  6. Once the TI Connect software install process has completed, restart the computer before using TI-Connect.
  7. Attempt to transfer data to the calculator.
If these steps do not solve the problem contact TI
Jan 30, 2010 | Texas Instruments TI-84 Plus Calculator
Every time I turn on the calculator, it gives me this message: Waiting... Please install operating system now after a while, the screen changes to: ERROR! Press any key to turn unit off. Then turn unit...
Read the following from the TI knowledge Base. Hope it helps
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
Oct 28, 2009 | Texas Instruments TI-84 Plus Silver...
Turned on calculator and screen reads operating system not found install OS now
Here it is from the horse's mouth (TI Knowledge base). Please read till the end.
I hope it helps.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Oct 27, 2009 | Texas Instruments TI-84 Plus Calculator
TI 84 won't turn on. New batteries installed. TI Connect recognizes device and I installed new OS. Brightness is not the issue. Any suggestions? This is one of student's calculators. Thank you.
Sorry, answer was posted as a clarification request.
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
I changed the batteries and now it will not come on
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create backup using TI Connect™ first.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83 or TI 84 Plus family to reinstall the calculator operating system (see below.)
Reinstalling the OS for the TI83/TI84 Plus family
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TIConnect installed on the computer.
Hope it helps.
Oct 11, 2009 | Texas Instruments TI-84 Plus Calculator
Replaced the batteries and downloaded the software
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
Hope it helps.
Oct 05, 2009 | Texas Instruments TI-84 Plus Calculator
I need to reformat my NEC e3100 because im experiencing all kinds of internet issues and software issues where my computer doesnt even recognise any programs installed. how do i go about resetting it. i...
To reformat usually you either use a windows install disc and reinstall windows, or you use a boot disk and a format utility, depending on the windows version. There are also format discs such as UBD that also work. When you format your drive, you lose all the information on it. You also will need a windows disc and serial number to install after a format.
The easier way to get your computer working is to simply use your windows disc to re-install windows. Before doing that it is a good idea to run several different virus and spyware scanners as well as a registry cleaner. RegScrubXP is a good one to use. When windows is running, simply browse to your windows disc and run setup.exe, that will reinstall windows over top the copy you have and replace any damaged or missing files. Then reinstall all your programs and it should all work. Programs can be re-installed over top even if they already are installed, basically all that happens is the missing files are replaced. Re-installing does not give you two coies of the same program - it just makes the copy that is already there work again.
Windows 2000 and XP have a feature for repairing also, in the start/run menu, type sfc /scannow and put your windows CD in, it will then check all files and replace any damaged or missing ones.
Aug 31, 2009 | NEC Versa VX Notebook
Recovery Disc will not work
That's terrible. The right soution should be to try Ashampoo Uninstaller or similar software that gets off EVERY BIT of unwanted software. Use function "Install new applications". It asks for setup.exe, install.exe or similar executable file, that runs Antivirus 360 installer. Point to it. After all the installations completes, "Ashampoo Uninstaller" logs the installation. Now uninstall the unwanted program using "Uninstall logged programs". That's it!
If you really damaged your operating system, do buckup of your important data and reinstall OS
Feb 04, 2009 | Toshiba Satellite A105-S4034 Notebook
Installing PrintMaster Platinum 16
The program should give you a choice of Typical Install, Full Install, and Minimum Install. Choose Full Install, however she may still need some of her discs for some of the art since the program may not load all the art anyway.
Jan 11, 2009 | Broderbund PrintMaster Platinum 16
Paperport 10.0 deleted by repairman.Lost discs and access to data. Cannot reinstall.program.
my only suggestion is to download and install a trial copy then retrieve your data that may have the serial number for you to register again.
good luck
Terry
Mar 19, 2008 | Computers & Internet
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
109 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
