Question about GE Washing Machines
I have a FE WCVH6260. Multiple times every cycle the machine door will unlock, and the cycle will stop. It will only restart when the "start/stop" button is pushed again.
  • 1 more comment
  • silthu Aug 11, 2008
    The locking mechanism does not appear to be sticking. The wash cycle starts normally, but will stop part way through.
    In response to bestdarngood:
    I cleaned the filter out prior to coming to the forum, but it didn't appear to work.
    please see previous comment
  • 481 Answers
  • I have experienced this problem with a a lot of machines and it almost always was the door lock latch assembly.
  •  it has a switch inside it that pauses or stops the cycle if the door is not closed properly, when this switch malfunctions then it will pause or stop the cycle repeatedly; just from the small movement of the wash cycle.
  • the door will actually be shut all the way and the lock may be on; nothing will seem to be wrong.
  • these door switches are expensive but if you shop around you can get one fairly cheap.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Aug 12, 2008
  • 2,071 Answers
WHAT IS WRONG WITH YOUR WASHING MACHINE?
I have a FE WCVH6260. - small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
Posted on Aug 11, 2008
  • 3,037 Answers
Try cleaning out the filter on the machine. Give it a try and let me know how it then works for you
  • 319 Answers
Please check the door latch device. Be sure that the latch is not bound or sticking in any way. Let me know what you find on the door latch.
Brian
  • Brian Berndt
    Brian Berndt Aug 11, 2008
    I believe that you may have a faulty DSA door switch assembly.
    See this article for descriptive info!
    Regards
    Brian
Front loader leaking out the front door as is clothing stuck in it, How can we release the door lock. We've stopped the cycle.
Restart the machine...
On a NEW CYCLE... The first thing the machine
should attempt to do... is to drain itself.
If it does not...
UNPLUG IT... Restart it on a spin cycle ... or regular
wash cycle...
Carnac the Magnificent YZQ7YL
Jan 21, 2017 | Washing Machines
Washer wont complete cycle
Sound like the control board is bad
Jul 25, 2012 | AEG Lavamat 72640 Front Load Washer
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Door open error on frigidaire affinity atf6700 washer
hello, it sounds like you have a bad door latch that needs to be replaced if you need a web sight on were to order one let me know and i'll find the part for you.
Mar 29, 2009 | Washing Machines
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Control lock is on but door opens it finished the cycle but the control lock wont shut off can you help thanks
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Apr 13, 2008 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
108 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
