Question about Samsung SCX-4100 All-In-One Laser Printer
Printer displays 'No paper - Add paper'
I receive the above message although the paper cassette is full. I have tried the suggestions made by others at FixYa, but the SCX-4100 will not print although it prints if manually fed.
I believe the papaer sensor micro switch if not functioning. The paper feeler has not life in it and it moves freel<. How does one open such a printer to try to shortcut the micro switch?
Thanks for your replies. ..john
  • 2 more comments
  • Anonymous Oct 27, 2008
    i have same problem paper out when full is this driver issue
  • vaughans126 Nov 04, 2008
    I have exactly the same problem
  • warbz1959 Nov 06, 2008
    I also am experiencing the same problem
  • Anonymous Mar 30, 2009
    I also have the exact same problem. Can anyone solve this problem?????
  • 4 Answers
That is if the lens present in your printer ( above the paper Tray) must have filled with dust. just clean the lens and try it out.
Posted on Apr 18, 2009
Even though cassette is loaded it keeps saying "add paper in cassette" and will not print
theres a sensor where the casset meets the back of the machine if it dosnt get triggered it wont see any you can trick it and it will always see paper just keep it stocked of paper
May 30, 2014 | Kyocera FS-2000D Laser Printer
SCX-4216 "No Paper" message
Check this link it has a step by step solution that you can try
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
This error code indicates a problem related to paper cassette lift mechanism. First thing that you will need to check is, if the printer makes some strange noises at initialization, when the printer is trying to lift the paper inside cassette. You can verify if the lift mechanism on the printer is ok, by removing paper cassette and press the 3 small white switches on the left of printer. At this moment the printer is trying to lift the cassette and you will see a gear that rotates on the right side of printer. Also verify if the GEAR LIFT Z64 is intact by opening the gearbox(the big one from the gears from the right side of paper cassette). This gear is cracked in most cases. Replace it.
May 06, 2014 | Kyocera FS-4000DN Laser Printer
False paper out message
An 'Out of Paper ' error message displays on the product control panel display, and the product does not pick up or feed paper from the photo tray.
Try to reset the printer:
  • Disconnect the power cord from the electrical outlet.
  • Disconnect the USB or Ethernet cable from the back of the product.
  • Disconnect the power cord from the back of the product.
  • After 30 seconds, connect the power cord to the back of the product.
  • Connect the power cord directly to an electrical wall outlet.
  • Connect the USB or Ethernet cable to the back of the product.
  • Try the print job again.
If you need any technical help on printer then you can reach at
Nov 16, 2012 | Xante ScreenWriter 4 Laser Printer
My Samsung SCX-4200 printer says '[No paper] Add paper,' when it actually has plenty of paper. I've tried switching off both printer and computer at the wall, after which it will print just one thing but...
please remove your paper cassette.
and there have paper sensor(it's black colour and its like a hook) between paper cassette and machine.
it's broken
you have to replace it.
Jan 31, 2011 | Samsung SCX 4200 All-In-One Laser Printer
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
Message keeps paper tray is full and it is full.
pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Displayed fault is 'Paper Jam'
you amy need to reset your printer let me no if you need the info on how to reset your printer
Sep 17, 2008 | Epson Stylus Photo R300 InkJet Printer
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Samsung SCX-4100 All-In-One Laser Printer Logo
154 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
