Roxio10 Deluxe Suite, Vista OS - When editing an audio CD label (back of jewel case), all text disappears from project window. All text is still there if you go back to Edit Text but still gone from project window. Others have same problem but no real solutions. HITTING CTRL & Z twice brings original text back to project window but not the edited text. Thank you in advance!
Since Roxio will not aknowledge this issue, I am using Publisher to create my CD jewel cases. I am also using other software programs as work arounds for other Roxio issues that I have. Roxio has really gone down hill since version 7! After being a Roxio user for many years (and several versions), I will no longer encourage others to buy this product.
Posted on Aug 12, 2008
My conformation code for simcity 4 deluxe isnt working. how do i get a new one?
Confirmation code(s) are NOT used for SimCity 4. That method is only found on programs requiring online activation.
SimCity 4 Deluxe Edition uses the 20-character REGISTRATION code found on the back of the CD case. If you've lost the case, you're out of luck.
The good news is - Being a very old game, it'll be very cheap to buy If you can find it online.
Dec 12, 2014 | Electronic Arts Sim City 4: Deluxe Edition...
How to create bootable cd?
The following items are required:
  • A copy of the original Windows CD/DVD or ISO.
  • A copy of the Boot Files (Downloaded Below).
  • A minimum of 1GB available hard disk space for CD's.
    A minimum of 5GB available hard disk space for DVD's.
Create a folder called OS on your hard drive (C: is used in this example).
In this folder create two sub-folder called BOOT, and ROOT.
Copy the entire Windows 2000/XP/2003 CD (or extract the ISO) into folder ROOT.
1.) Download boot file. (bootfiles-from-tacktech-website.zip ~1.34KB)
2.) Extract the BootSector file (boot.ima) from bootfiles-from-tacktech-website.zip
into the folder C:\OS\BOOT
Start Nero Burning ROM.
Select File > New... from the menu.
1.) Select CD-ROM (Boot).
2.) Select Image file from Source of boot image data.
3.) Check Enable expert settings (for advanced users only!).
4.) Set Kind of emulation: to No Emulation.
5.) Set Load segment of sectors (hex!): to 0000.
6.) Set Number of loaded sectors: to 4.
7.) Set Platform identifier: to Intel x86 compatible.
8.) Press the Browse... button.
Locate the BootSector file (boot.ima) in the folder C:\OS\BOOT.
Click the Open button.
Click on the ISO tab.
- Set File name length to Max. of 31 chars (ISO Level 2).
- Set Format to Mode 1.
- Set Character Set to ISO 9660 (standard ISO CD-ROM).
- Check the Joliet check box.
- Check all Relax ISO Restrictions.
- Check Allow more than 64 characters for Joliet names.
Click on the Label tab.
Remove the check from Also use the ISO 9660 text for Joliet.
Enter the Volume Label into the ISO 9660 and Joliet text boxes.
Click the More fields button.
- View Windows 2000 CD Labels (TTID# 269)
- View Windows XP SP0 CD Labels (TTID#226)
- View Windows XP SP1 CD Labels (TTID#283)
- View Windows XP SP1a CD Labels (TTID#312)
- View Windows XP SP2 CD Labels (TTID#342)
- View Windows XP SP3 CD Labels (TTID#422)
- View Windows 2003 Server RTM CD Labels (TTID#292)
- View Windows 2003 Server SP1 CD Labels (TTID#355)
- View Windows 2003 Server R2 Disc Labels (TTID#387)
Enter in the Volume Label into the System Identifier, Volume Set, Publisher,
Data preparer, Application
text boxes under ISO 9660 and Joliet.
Click the OK button.
Click the Burn tab.
- Check Write.
- Check Finalize CD (No further writing possible!).
- Set Write Method to Disc-at-once. (We have had Track-At-Once work as well.)
- Click the New button.
- Locate the folder C:\OS\ROOT.
- Select everything in the folder and drag it to the ISO compilation panel.
Note: Some files are not show in the following image.
- Click the Write CD Dialog button.
Click the Boot tab.
- Verify the settings. Correct if needed.
- Click the Burn button.
Wait for Disc creation to finish.
Click the Done button.
Process completed. You're done.
Regards
Pcs365.8
Jun 01, 2010 | Microsoft Windows XP Home Edition
How do i obtain product key number for my new laptop
If u have genuine Operating System preloaded in your laptop, then turn back your laptop you can find the serial number pasted on it. If you don't have the genuine OS preloaded then you can find the serial number on the back side of the CD Cover label.
Nov 04, 2009 | Microsoft Windows Vista Ultimate Edition
My pc needs a product key for office 2007
Check your original installation media for the product key (normally on the back of the CD sleeve or jewel case) and type it in. Otherwise, you will need to contact Microsoft to get (another) product key.
May 29, 2009 | Microsoft Windows Vista Ultimate Edition
Sotware would not work with Vista
are you sure you have the right version? check for it compatibility with vista or get its vista edition.....
if non exist then try it on windows xp......
May 06, 2009 | Broderbund PrintShop PhotoPro Deluxe for...
Argox 214 not compatible with vista
Thermal printers seem to be notorious for that.
Try using Vista's "Generic/Text" printer driver (you'll need to go into device manager, select to update the drivers, go to Have Disk, select "generic" as the brand). That will send raw text to the printer. Many thermal printers support this.
After you do that, you will also need to go into your printer settings and setup a custom page size that matches the size of your labels. Then you should be good to go.
Jan 02, 2009 | Argox OS-203 Thermal Label Printer
Cannot load "arthur" with widows vista home premium stops installing
Hello... Please go thru this. Souce:http://www.ataricommunity.com/forums/showthread.php?t=573497
I may have a work around
It is a way to give admin privs to the msi file
First, create a file called Arthur.bat
- Open a folder, say C:\temp
- Right-click and select new, Text Document
- name it Arthur.bat
Next, edit the file
- right click the file and select edit
- put this in the editor ... msiexec /a d:\Arthur.msi
- save and exit
Then, right-click the file and select "Run as administrator"
Worked for me.
There is another msi file (ISScript11.msi) on the CD which I didn't run which may be needed ? But, I managed to play through the tutorial/start so ... we w ill see.
So, it is a permissions thing. Hopefully this will get passed on to the developers and they can resolve it tout-de-suite
Nov 02, 2008 | Atari Arthur & the Invisibles for Windows
I purchased the Memorex cd-dvd LabelMaker/starter kit. It also say's exPressit/ label desin studio, powered by Sure Thing , when trying to use the help menu to access the tutoral, I find that the help...
Try inserting the cd and opening any help files through a programme like notepad or wordpad,you may find a text version of help files.
Use windows explorer to browse the cd
Apr 21, 2008 | Computers & Internet
50 people viewed this question
 Grubhead
Grubhead
