Question about Uniden CLX485 Cordless Phone
Telephone stopped working EO error
I reconnected my phone after a move and the base doesn't seem to work now. Everything is blank and it has EO on the screen. The secondary handsets say to check the AC adapter. The AC adapter on the base is plugged in but the charge light doesn't come on. Its charging though the handset has full charge and the speakerphone light flashes every few seconds.
  • Anonymous Nov 20, 2008
    EO CODE AND BLANK SCREEN AFTER POWER OUTAGE ...PLEASE HELP
  • sentim Feb 22, 2009
    I have the same problem, when I placed the phone on the base the base light flash but no charging. When I put on to the single charger (2nd) base it showed charging but it won't do anything everything is black. Please help.
SOURCE: Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Posted on Jan 21, 2007
SOURCE: Uniden DCT648 register phone problem
I have contacted Uniden about solving this problem. They suggested I clear the eeprom on the handsets and reset the base. To clear the eeprom detach all of the batteries and reattach while holding the star and pound. You'll hear a beep. Press select and the unit will clear the eeprom. Now hit end and the unit will say "Welcome...something or other". Next unplug the base unit reattach while holding delete. Next hit delete twice...the base is reset. Apparently this is the last possible solution to marrying the handsets and base. This didn't work for me and the units have been declared dead. Good luck in solving your electronic problems.
Posted on May 14, 2007
SOURCE: Handset locked on Binatone lifestyle signature telephone
just hold down the pound key and it should unlock.
Posted on Nov 27, 2008
SOURCE: Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
Posted on Sep 20, 2009
SOURCE: ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Posted on Oct 09, 2009
Phone handset screen is blank. It says Searching and when I press a button it goes blank.
Try unplugging the battery inside and reconnect it and put it back on the charging stand
Mar 02, 2015 | Uniden DECT 6.0 Cordless Telephone...
My DECT6.0 telephone will not give me a dial tone nor answer any calls neither will the additional handset..Although my verizon direct line functions as it designed
Hello.
Here are some tips, found online:
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes that way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the surge protector:
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone. It could be that the phone line plugged into the surge was loose or not plugged in securely.
Try a different phone plug, outlet.
Check the base:
Is the base dusty and have possible dirt in the prongs where the phone sits? Lift the base and blow off dust.
Check the handset for dirt.
Rub metal connections on handset and base:
Use a pen cap or coin and rub the metal connections on the bottom of the handset. Rub the prongs, metal connections on base.
Hope these suggestions help.
Jul 25, 2011 | Uniden Cordless Phone
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
TIP: IF REGISTRATION FAILED, REPEAT THE ABOVE PROCEDURE.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
No one can hear me talking
Electronics do not like liquids - especially those containing milk, sugar, salt etc.
Do NOT try to dry out with heat or a microwave.
You could try this for the handset:-
Remove the battery cover and disconnect the battery.
Let everything dry for at least three days with the battery cover off.
After everything is dry, reconnect the battery and replace the cover.
Do not reconnect the phone line to the base - as phone calls will interrupt the charging.
Recharge the battery for at least 15 to 20 hours without interruptions.
If the base got wet:-
Disconnect the AC adapter to cut off the power.
Disconnect the telephone cord.
Let everything dry for at least 3 days.
Reconnect (and cross your fingers).
It is a wise safety precaution to have a safety-cutout plug or switch to avoid electric shock (to you and your equipment).
Mar 27, 2010 | Lands Phones
Load default Delta file message
Problem My handset displays either LOAD DELTA FILE or LOAD DEFAULT DELTA FILE. What should I do?
Solution(s) Tip 1 of 2
If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
Nov 16, 2009 | AT&T 650530003417 Cordless Phone
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
Out of range
I have a Radio Shack 2.4ghz cordless phone system and sometimes the handsets will show "Out of range".
My Solution that works for me.
Unplug the power cord and telephone line to the base for about 30 seconds. This seems to reset the base. Then plug everything back and you should be ok.
ET Sherman
Oct 07, 2007 | Panasonic KX-T7730 Corded Phone
V-tech 2498 landline phone with cordless
Tip 1 of 2 Recradle the handset for 15 seconds, then lift the handset and press PHONE. Tip 2 of 2 If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system: Step 1: Disconnect the power to the telephone base. Step 2: Disconnect the handset battery. Step 3: Wait a few minutes and then reconnect the power to the telephone base. Step 4: Reconnect the handset battery Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again. If that does not work, call the manufacture at 1-800-595-9511. Or take it back to where you purchased it and have then exchange it.
Jul 08, 2007 | Vtech Cordless Phone Battery for 2429,...
I have a phone from Vtech
Having researched this phone, the message feature you have is voicemail. The machine itself does not have an answering machine in or on it. First make sure that you have voicemail through vonage. And check with them that the voicemail notification that they provide is compatable with the Vtech phone. Next try these steps Tip 1 of 7 Your phone is designed to work with most local and regional telephone service providers? voice mail systems. Voice mail (also known as voice messaging) is a subscription service, available from most service providers for a fee. This feature does not work in conjunction with your home answering device. Contact your local telephone company for more information about their voice messaging system. Tip 2 of 7 Your voicemail feature is compatible with both stutter and FSK signals from your local phone service provider. Contact your service provider to ensure you are receiving one or both of these signals. Tip 3 of 7 Move the handset closer to the base. The operating range may vary with environmental conditions and time of use. There may be places within your environment that a cordless phone will not work well. If the VOICEMAIL light on the base is flashing in the presence of unheard messages, however your handset does not display MESSAGE WAITING, it is likely your handet is out of range from the base. Tip 4 of 7 Other electronic products (i.e., 802.11 wireless networking products, radios, radio towers, pager towers, cell phones, intercoms, room monitors, televisions, personal computers, kitchen appliances and other cordless phones) can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices. Tip 5 of 7 The VOICEMAIL light on the base will flash and MESSAGE WAITING will be displayed on the handset only if there new, unheard messages. Once all new messages are heard and the phone is returned to the idle (OFF) mode, these indicators will be turned off. Tip 6 of 7 If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system: Step 1: Disconnect the power to the telephone base. Step 2: Disconnect the handset battery. Step 3: Wait a few minutes and then reconnect the power to the telephone base. Step 4: Reconnect the handset battery Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again. Tip 7 of 7 If the other phones in your home are having the issue, the problem could be related to the telephone wiring in your home, or with your local telephone service. Please call your service provider for further assistance. If this does not help, repost with further info. Please rate this solution throigh fix-it. Thank you
Jul 02, 2007 | Vtech ia5823 Cordless Phone
Cordless phone does not connect
I have the very same problem and it was after storing numbers into the directory, although that may not have anything to do with it.
Jan 23, 2007 | AT&T E5908 Phone
Uniden CLX485 Cordless Phone Logo
63 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
