Question about Dell 3010cn Laser Printer
Colour Printing jams in Fuser
Printing in black without any problems at all. When printing in colour if the document has a heavy colour header it gets stuck in the Fuser unit and wraps around the roller. I am using non standard toner cartridges and think this may be something to do with the problem...any ideas anyone?
  • 49 Answers
Have you tried replacing the non standard toners with different ones?
Posted on Feb 27, 2009
Wont print in full black, does print in grey or any other colour.
Assuming you are using MS Excel, try going into page setup, sheet, and check the setting for 'print black & white'. If it is checked, then try unchecking it.
Apr 18, 2016 | Office Equipment & Supplies
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
We have a HP Color Laserjet 3600 printer. Printing a text, the right side is very pale. Printing pictures, they turn out unclear with strange colors. We have new cartridge
The laser unit on your machine may be dirty,
The first colour that normaly goes fuzzy is the red.
The problem may also be on your fuser unit,
Rub your finger over the printed area, and if the image gets smudged the fuser unit isnt fusing the toner proprly
Feb 10, 2011 | Office Equipment & Supplies
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Colour printing gives ghost image
Are you using genuine Brother color cartridges? If you are, then try different paper (20 pound laser printer paper or plain paper copier paper rather than inkjet paper,) Also, do not use recycled paper. If that does not work, you may need a new imaging (OPC belt) unit, or a new fuser assembly. Check your owners manual about when to replace the imaging unit or fuser. It is usually after 60, 000 prints have been run.
Jun 09, 2008 | Brother MFC-9420CN All-In-One Laser...
Poor Print Quality on Epson Aculaser C1100N
Sounds like the black dev unit is worn out. Easy enough to change yourself if it is out of warranty. If it is in warranty get Epson to do it for you.
Jan 24, 2008 | Epson Aculaser C1100 Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Dell 3010cn Laser Printer Logo
75 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
