Question about Lexmark X8350 All-In-One InkJet Printer
Can't receive faxes
I have a lexmark x8350 all in one machine and up until a couple of weeks ago i cannot receive faxes, i went thru all of the troubleshooting guides reconfigured the fax machine rebooted and everything else, all i get is a busy signal and no response
  • mhacoord Oct 01, 2008
    hello, big deejay, you know i did adjust my incoming rings to get the faxes coming in and that fixed the problem, i want to thank you for your help, it was great at least to know that there is someone out there who cares enough to answer, again thanks
I just wanted to know can you adjust the incoming phone calls to fax machine
Posted on Sep 30, 2008
I cannot get my Lexmark X8350 to fax out
Are you getting any error messages when faxing? Have you sent a fax successfully before? Make sure the printer is connected to the correct active phone line in the wall and the telephone cord is plugged into the LINE port of the printer. If problem is more of signal quality, try to lower the transmission speed to 9600 bps. Press the Fax button, then press Options 15 times to get to ADVANCED FAX. Press Select. Press Options ten times until MAX SEND SPEED appears on the LCD display. Change it to 9600 BPS using the - (left arrow) button. Press Select.
May 05, 2011 | Lexmark X8350 InkJet Printer
I cannot send or receive faxes. The Transmission Error report says phone line error. I don't know how to set up the fax software; cannot find my Lexmark x8350 manual. Thank you.
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Jun 20, 2010 | Lexmark X8350 InkJet Printer
I cannot receive faxes on my Lexmark 7350 All-in-One. I can send them Fine
hello there, Try Connecting the Lexmark All-in-One directly to the phone port...but make sure that Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
If this does not work then do get back for any further help.
Thanks
Mar 05, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Fax: Sending a fax is working well but I cannot receive a fax!
I found the software on Lexmark.com and reloaded it and now the fax works as intended.
Dec 11, 2009 | Lexmark X8350 InkJet Printer
Canon 1023if not receiving faxes automatically
Is this fax line shared with the phone? I believe there is a distictive ring setting in the add'l functions area under communication settings then receive settings. you would need to select a ring pattern different so the fax can tell between which types of calls it is receiving.
It has worked for me in serveral other installs
Hope this helps
TankMurdock
Apr 09, 2009 | Canon imageRUNNER 1023iF Black and White...
Lexmark 8300 print/scan/fax
There are sensors in the document feeder that detect the width and length of the paper being copied or faxed. Try getting a can of compressed air and go nuts blowing all the dust out of the feeder, if you spray everything you can get to, you will probably blow clean the sensors. Just an educated guess.
Good luck,
Printdoctor
Jun 19, 2008 | Lexmark X8350 All-In-One InkJet Printer
Cannot recieve faxes
I just spoke with customer service live chat.
-press the "Fax Mode" button
-press the menu button
-The Fax menu screen will be displayed
-press down arrow button 5 times until the screen displays "Ringing and Answering."
-press the select button
-the display will show the "Ringing and Answering menu
-press down arrow button 4 times untip "Pick-up On?" is highlighted
-press the right arrow button 2 times until the screen displays "1st ring"
-press the "select" button and now "1st ring" will be set as the default.
Apr 01, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X8350 All-In-One InkJet Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
