I have a Sony Air 7 radio. The volume control is faulty, it only works at full volume. I have taken the back off the radio but can't access the area around the volume button.
  • Anonymous Aug 22, 2008
    My problem is exactly the same. If you find a solution please let me know!
HI I HAVE FIXED THE SAME FAULT ON MY SONY SCANNER BUT NOT FOR THE FAINT HEARTED!. YOU WILL HAVE TO UNSOLDER AND EXTRACT THE CONTROL AS THE TRACK SPRING LEAVES HAVE BECOME WEAK AND ARE NOT TOUCHING THE TRACK PROPERLY.CAREFULLY TAKE APART THE CONTOL CLEAN ANY RESIDUE ON THE TRACK AND CONTACT SPRINGS THEN RE ASSEMBLE AFTER SLIGHTLY BENDING THE CONTACT LEGS TO IMPROVE PRESSURE ON THE TRACK. BEST OF LUCK I HAVE GOT A SPARE WHICH MIGHT FIT YOUR MODEL. CHRIS
Posted on Aug 01, 2009
Brian here well I found the sony air 8 in a box,i got it years ago and just refound it..i love this thing.
can someone tell me the best ways to use it and what the best way to pick up sounds from a long way away,
please email me as im not on my computer, glassblower4u@yahoo.com
Posted on Nov 07, 2008
Using something like CRC's CO contact cleaner (http://www.crc.co.nz/item_prod.asp?pid=184), spray down near the volume control with the supplied extension tube. About 2mls should do it. It's real tricky to get to the inside of the volume control on this device but somewhere close should do the trick.
Problem is caused by dust inside the potentiometer. I have the same unit that had the same problem, this sorted the problem for me. It won't be a permanent fix but it should but you a few more years.
NZ Electronics Tech
Posted on Oct 11, 2008
The radio plays full volume on right channel when turned on.
Anything I tell you is going to be a guess, since there has been no testing done, and we don't have the model number of the specific radio involved. However...
For a 20 year old radio, the volume and balance is almost certainly controlled by a potentiometer that has input into one leg of the fixed resistance, and the other leg (of the fixed resistance) is grounded. The movable center tap is the output to the amplifier - and its position controls the volume to that channel. If the ground leg becomes disconnected (broken wire, or a cold solder joint, or even a break in the resistor within the body of the potentiometer) then instead of "dividing" the volume, it simply provides a slight resistance inline - short answer: It goes full volume.
You can try running the control full range back and forth, and even just the old time "slap it" approach, to see if you get any static or change. If you do, that pretty well confirms the diagnosis. [If not, it just means the break is not close to touching - still almost certainly the right answer though.]
Only fix is going to be disassembly. You then may be able to find the break (and resolder it), and/or replace the volume potentiometer. Note that if you have remote volume/balance control (controls on the steering wheel), then there is some extra wiring that can likewise be involved. jk
Feb 27, 2015 | 1995 Jeep Grand Cherokee
How can I reset the volume control? All of a sudden, I can barely hear with the volume set at max.
You do not mention the type of Motorola radio so this answer will be general. You may have a problem with your volume potentiometer, Receive (Rx) sensitivity, or a speaker problem.
The volume pot on a 2-way radio is a common failure item, and will after repeated use possibly fail, or get dead spots. Try backing off your volume to 75% and see if it is louder at this setting. If so, you have a bad volume pot.
Rx sensitivity can be caused by various internal problems with the radio,and some models are more prone to this than others. Operating your radio at full volume most of the time can bring this issue to the forefront. (Tip: Try running your radios at 80-90% volume vs. full volume to alleviate this problem.) If this is your issue, your effected radios are in need of repair. Most repair facilities (including ours) can correct Rx sensitivity in most models during a repair.
Speaker problems: If you work in an environment where dirt, debris or metal shavings can get inside the speaker, your speaker may fail over time. Or if you run your radio at full volume the majority of the time it can cause your speaker to fail.
Best regards.
Oct 13, 2014 | Motorola Walkie Talkies 2-Way Radio
Radio volume control on 2007 Subaru Tribeca does not work, but remote volume control on steering wheel works. Any suggestions on repairs?
Radio volume control on 2008 Subaru Tribeca does not ...
www.fixya.com/.../t25735073-radio_volume_control_2008_subaru_trib...
Jun 7, 2015 - Radio volume control on 2008 Subaru Tribeca does not work, but remote volume control on steering wheel works. ... does not... Replace the volume control(rheostat) inside the radio. .... Oct 09, 2014 ' 2007 Subaru B9 Tribeca.
Nov 04, 2013 | 2007 Subaru B9 Tribeca
Acura tl 04 radio volume at full can barely here it
Just try to spray contact cleaner in it thru volume control knob area by removing knob outward.The proper way is cleaning by spraying in the audio control switch from inside but because it is bit difficult job,Hope it will solve the issue.
Jan 08, 2013 | 2004 Acura TL
Blaupunkt radio/cassette goues full volume when first tuned on. i.e from the radio or when car is restarted. Once the volume control is touched volume drops to nothing and then back up to full volume...
The volume controll is wore or dirty on the contacts in side of the switch youll have to probley have to get it replaised to cure the problem.
Aug 24, 2010 | Car Audio & Video
Radio cuts off and back on seems to be vol related
This is cause by many things one of which is a faulty speaker that is going short when operated at high volume. Another is the wiring supply the power to the radio is not "thick" enough hence not able to supply the demand for extra current. Had this same problem with Golf II which I replaced the main supply wire and after that it went to full volume with no cutting off.
May 12, 2009 | Sony Car Audio & Video
Harmon/Karden 2006 Radio/CB/CD Passanger control does not work
The passenger controls on the rear speakers are pretty easy to diagnose.  The wire for Volume up is Pink/white, the volume down is gray/white.  If the Pink/white wire is shorted to ground somewhere, then as soon as you turn on the radio, it will be like having the volume selector pushed up, and it makes sense how you describe it goes to mute and then returns to full volume as soon as you let go.   You don't say what model it is (I doubt it's a Road Glide, gotta be an Ultra), so it's not too hard to get at.  Pull the outer fairing and look on the back of the HK Radio.  There are 2 big connectors, when looking from the front you want the connector on the right.  Pin 23 is down volume, pin 34 is up volume for the rear controls ONLY.  So I would check the continuity to ground at pin 34 first, in other words pull the connector off the back of the radio, take a test lead and hook one end to +12v. Touch the tip to any grounded metal and it should light.  Now touch the tip to pin 34 on the harness side of the connector.  If the test light lights up, you have a short to ground on the pink/white wire.  Now go to the right rear speaker on the tour-pak and disconnect the 6 pin connector and try the test again.  The pink/white goes from pin 34 on the radio and runs through the harness to the passenger controls and nowhere else.  It shouldn't be grounded anywhere.  Let me know what you find out.
Jan 13, 2009 | Harley Davidson 426290 AM/FM Radio
2006 ultra radio has no sound
This is a very common problem with this radio there is a part in the radio that controles volume and it breaks down after a period of time due to vibration... If you need any repair help you can email me at HRmotors@aol.com I no these radios inside and out and would be happy to help you- thanks
Volume control on in-dash unit not working properly
Sony CDX-GT300 volume control stopped working. Radio is either on full-blast, or you have to turn it off. Any solutions? Thanks!
Aug 03, 2008 | Car Audio & Video
2,038 people viewed this question
 Grubhead
Grubhead
