Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirpool Ultimate Care II washer Imperial Series spins at low speed
Spins at low speed even when set for high speed spin. Water drains from the tub okay, but clothes remain very damp.
  • Anonymous Mar 19, 2014
    sometimes will not spin
  • 481 Answers
It sounds like a worn clutch. Whirpool Ultimate Care II washer Imperial Series s - ab164bf.jpg
Posted on Aug 12, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool Washer LSQ9500LQ0 Won't Spin or Drain
Your belt assessment sounds correct on the dryer problem.
If you can, restore the lid switch connections, and operate the switch during what should be spin. You should be able to hear a relay or solenoid clicking off and on with the switch.
Aug 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Barrell doesnt spin
Check the drain hose if to low to ground if so raise hose up to even with the tub top or two thirds up on machine. Some washers don't spin until water is drain out first then the pressure switch turns the timer to spin. Hope this may help.
Jun 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Aggitator or tub not spinning after move from detroit to LA
IT SOUNDS LIKE YOUR DRAIN HOSE IS LOWER THAN YOUR TUB WATER LEVEL BE SURE THAT YOUR DRAIN HOSE IS ABOVE THE TUB LEVEL.GLAD TO BE OF SERVICE
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II spins only once in a while :-)
hi there,
sounds like the timer switch. the switch is mechanical, so it's quite easily replacable.
also, the overfilling is a result of the pressure switch no engaging. this switch senses the water level and once it's up to capacity, it will shut off the water supply into the tub. check the switch and switch wire to make sure it's working correct. this switch is also mechanical and easy to fix.
let me know if i can be of more help.
thanks
Sep 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
No high spin
Make sure you are set for normal cycle. Some permanent press cycles only spin on low. Also check that your drain hose is not kinked. If it is the water may not be draining fast enough.
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
966 people viewed this question
Dan Webster
Dan Webster
Sal De
