Question about HP LaserJet 1300 Printer
HP Laserjet 1300 will not feed paper
You mention in your email that is easy to fix the problem I am having with my HP Laserjet 1300 (paper will not feed into printer). I can that the paper is pushed up, but it is not picked up by the pinch roller. I have tried various thicknees of paper, but no luck. I tried the laserjet cleaning paper but still no luck.
Is there a way to adjust the pinch?
Walter
wremson@austin.rr.com
    Problem Solver:
  • 25 Answers
You may need a new roller, or pad.
Posted on Aug 14, 2008
LESERJET 1300 NOT PICKING PAPER
Not picking up paper is usually caused by feed and pick up rollers worn out and has slick spots on then. Replace the rollers
Jan 26, 2014 | HP LaserJet 1300 Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Printer printed paper with crushing sounds, but
You need to continually press the paper feed button (next to power) while applying gentle pulling pressure to manually feed the paper all the way through the printer. Hope this helped
May 09, 2009 | HP LaserJet 1300 Printer
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer - Won't feed paper
firistly try to find out the printer is ready or not then find out when we powearing on the printer then it is warming up or not if it is warning up and not come to ready position then open front cover pull the toner cartage and send back it propely
then give print if the problem is not solved then ckeck the printer cables and drivers
Jun 28, 2008 | HP LaserJet 1300 Printer
H P LazerJet 1300 Problem
you most likely need the current drivers for that HP..try this link, through the HP icon doorway
Mar 20, 2008 | HP LaserJet 1300 Printer
HP Laserjet printer not printing
Try clearing the que. It may be the first job is to big for the memory. Also, be sure the printer is not in manual feed mode. The directions will be in the user manual if you are not sure how to change it.
Jan 19, 2008 | HP LaserJet 1300 Printer
My paper keeps jamming how do i solve it?
you need a new paper pickup feed roller- about $5.00 and easy to replace. This is generally the one part that wears out on these printers. see this article.
http://www.printertechs.com/tech/mkinst/mk-1300-3puroller.php
Dec 02, 2007 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
307 people viewed this question
Ben Johnson
