Question about Frigidaire ATF6000ES Front Load Washer
Frond load washer Frigidare ES1
Washer will not lock door. wash rinse and final spin lights are on what is going on?
  • 1 more comment
  • vicandlailah Aug 11, 2008
    My washer will not work. he door will no close and wash rinse and final spin lighs are on? why?
  • vicandlailah Aug 13, 2008
    I did as told and no luck I got a code EBF wht is this code?
  • Anonymous Mar 18, 2014
    loaded, all lights on panel look normal, but not start
  • 725 Answers
Press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 you need to replace door lock..
hope it helps
Posted on Aug 13, 2008
  • Franklin Ouchida
    Franklin Ouchida Aug 24, 2008
    Sorry Error EBF Console control problem. check all wire connections or Replace the control board.
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing
call a technician
Jan 01, 2018 | Hotpoint WMA46 Front Load Washer
Frigidaire Front Load Washer wont start!
sounds like you have a very unhappy control panel..unplug it, wait 5 min..and then plug it back in..if it does not reset, then you may want a repair job, no?
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
I have a Eurotech EWF150 frontload washer that does not spin. The drum will turn for rinse and wash cycle, but not spin. We checked the motorboard and there are 2 spots that appears burned. Hubby is trying...
I am not 100% sure your problem is the same as the one i had with my frigidare front loader but my door lock switch went bad. it would wash fine but when it came time to spin it only would tumble.
Jan 02, 2012 | EuroTech EWF150 Front Load Washer
Will not drain and spin keep beeping with error E20
  1. Remove the 2 screws on the bottom and the front access panel comes off.
  2. Pump is on the right, remove hoses from it, remove pump from machine and remove whatever is in the pump.
Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin LEDs should light. Any error codes should be displayed when holding those keys.
Feb 27, 2011 | Frigidaire ATF6000ES Front Load Washer
Wont go into final spin
The final spin on this model requires an additional lock from the computer to the door. Remove upper rear panel and look at board. Find the tiny resistor that says R-11. If it's burnt looking the board and the wax motor (at the lock) need replaced
Mar 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Aug 11, 2008 | Frigidaire ATF6000ES Front Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
E-43 still after a new control board
Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin lights should light. Any error codes should be displayed when holding those keys.
May 31, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
205 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
