Installing wii to panasonic viera 50'' plasma
Seems simple.. xbox 360 satellite connected to television (hdmi) add wii and I get sound no video. Move into bedroom and hook to 47'' Sony no problems whatsoever!... i must be missing something simeple right???
Aloha,
Paul
  • 2 more comments
  • darlene0 Aug 12, 2008
    I am unable to connect my wii at all to my panasonic viera. It is mounted and I am not sure which inouts to use since i cannot see them. Please show mw a diagram or tell me how to do this.
  • Anonymous Dec 27, 2008
    same problem with wii and panasonic viera 37"
    I have exact same problem
  • cjausmc04 May 16, 2009
    I have a 42" panasonic viera but cant seem to get it to work. I can't get the WII to show up on my screen. I have the 5 pin connector cord. There are input 1 and input 2 receptacles on the back of the tv should I use those and if so how do I find the channel for the WII to show up?
I could resolve the issue. First of all, the wire supplied with the wii is not compatible with your TV. This 3 point connector, will end up giving you b/w screen. So you need to buy the 5 pin connector. I bought from Frys for $19.99. The box says "High Performance Component HD A / V Cable" (like this one: http://www.bizrate.com/wii-accessories/oid875654433.html )
In any case, do below
1> find the 5 point input row (vertical) on the back of your TV.
2> Insert the connector, in the sequence of Red pin being the bottom most. If its 5 pin connector, then start from the lowest point on the back of TV. If its 3 pin connector, use the top 3 points, on back of your TV. Red always being the bottom most in sequence.
Once again, buy the 5 pin connector, as inserting these pins on the back of your TV when the TV is already mounted on wall, is the hardest part to do...so why to waste your enerty in doing again and again. I am sure you would not like the black & white screen coming with 3 pin connector.
Posted on Dec 27, 2008
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Can't get xbox 360 to work on tv
What here happened is that the GPU (graphics proccessing unit) has overheated and melted the VGA card (Video game array) card.
And this takes away the video/picture.
But you can still hear sound because the SPU is much much smaller and has a tiny chance of overheating.
So now the vga can't connect with the the CPU (motherboard) and the AV section.
You have to get it fixed, because this has caused or will cause the Ring of Death.
Call up Xbox at
australia: 1800-555-741
usa: 1800-469-9269
It'll get fixed for free because the xbox has a hardware failure.
Oct 12, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
Can i connect my panasonic viera th-42px8ou plasma tv,to my vista desk top? my tv has hdmi on it,my vista tower also says it has 1 hdmi connector on the back of it
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
Dec 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
I have a new Panosonic Viera TC-P54VT25. Everything seems to work well except for the sound on the Viera Cast. Viera Cast is connected through a hard wire ethernet connection directly into the TV. ...
I have had my Panasonic Plasma tv for 5 months there was a loud pop and the tv went off and now there is a red light blinking 10 times and the tv will not turn on.
Jun 15, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
CONNECTING XBOX 360 TO A LCD PANASONIC VIERA TV
You need to Connect via, the Component Video, the xables are Blue, Red, Green, ALL Video, and go color to color, from, Xbox to TV, and you Select EXTERNAL INPUT, on TV. OR You must use the Composite, Video, which is Yellow, for Video, again, cables go color to color. The Audio, as you have discovered, is Red & White. Now, if using HDMI, you do not usually need the Red 7 White audio, as it's all in the one signal, though the HDMI. Again, you select the relevant, INPUT On the TV, And also select the output on the Xbox, and you should be all OK.
Apr 30, 2010 | Microsoft Xbox 360 Console
H1005 error
I played with going to another HDMI outlet and then back to the original and it seems to quickly reset itself and the message dissappeared!
May 23, 2009 | Panasonic VIERA TH-C50FD18 50 in. Plasma...
Just bought a 50 panasonic viera, when we hook up ps3 on hdmi cable, we have sound but no picture.
Plasma TV normally do not have the resolution required for PS3 unless the plasma TV is fullHD( 1920x1080p) pixels.
HD Ready Plasma = 1024 x 768p
PS3 Outputs = (fullHD)1920x1080 or (HDReady) 1280 x 720p.
LCD TV accepts the resolution matches the resolution the PS3 is outputting.
Feb 28, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Televison & Video Logo
4,580 people viewed this question
Top Televison & Video Experts
Electro Med Services...
