Question about Riso RZ220 Duplicator
Riso I have a Riso GR1700. It no longer picks up the original paper you are trying to copy to make a master.I can manually place the original copy I am trying to copy under the cover and the machine will then pick up the original and make a copy. What must I do to correct the problem in the first step of this procedure? Thanks, Tim timconnie816@cox.net
  • 81 Answers
Probably needs a new adf stripper pad.. the first little rubber pad on the bottem of the inside of the adf
Posted on Sep 12, 2008
I need a copy of the operation manual of RISO RZ200EP C I have one from you?
Sorry, not from me directly. But from the original source - Riso:
http://us.riso.com/cms__Main?name=resellers_salesmarket_prodinfo_usersman
If you are fluent in German follow this link:
http://www.risographie.de/riso/index.jsp?page=57&lang=1#
Apr 19, 2011 | Riso RZ220 Duplicator
Can you use Riso GR1700 drums in a GR2700 or GR2710 machine? If so, is the ink also interchangeable?
The masters and ink should work. Cannot remember if the drum does. Put in the duplicator it will either fit or it won't. It will not damage the machine unless you try to force it in. If compatible it will slide right in and the machine will recognize it when you close the front door.
Mar 09, 2011 | Riso Office Equipment & Supplies
The riso rz 390 ui does not print the scans complete
Please check the setting of paper size. It may be set to a smaller format and therefore the outer original area is not transferred to the master.
If you meant someting other than please explain ...
Feb 03, 2011 | Riso RZ390 Duplicator
Film is separated from ink roller. How do we fix? Master copy not printing.
Seems that you have mismatched the sides of the master. Are you sure you placed the master correctly? An original Riso master should have a text at the side of the roll to show where the coloured flange should be.
Oct 14, 2010 | Riso RZ390 Duplicator
Code D-17-236 The Riso just stop working, Why?
A D17 is incorrect master roll installed. This could be caused by a) it IS the incorrect master roll, or b) the RF tag that is inside the master roll has gone bad. Try a new one in the original packaging to help with diagnoses. Make sure they are RISO Z type master rolls specific for an RZ220.
Jan 21, 2010 | Riso RZ220 Duplicator
Diffrent picture between the original document and master picture
You have to go to your page setup and set for the size you are printing. Also you have to go to the machine and look at the size the paper setting is at.. they have to match.. You may be printing 11 x 17 when the paper setting on the machine are letter.. This will do this...cause the machine will auto adjust to fit onto the settings on the machine.
Jul 22, 2009 | Riso Office Equipment & Supplies
Riso rc6300 registration not correct
ou need to either advance (paper feeds quicker) or elay paper feed there has to be a registration adjustment
It can be as simple as adjustment of the feed wheels or some type of delay in the drum rotation
take alcohol and clean the feed rollers they may be slipping
Dec 27, 2008 | Riso RZ220 Duplicator
E11 on riso gr 1700
When machine displayed E-11 it’s interrupted the operation.
Its means Pressure Control Motor Lock –
If the Pressure centering sensor does not detected on & off within 5 seconds from the start of the machine.
This problem is the engine of pressure, this is located by uncovering the back, more or less in the middle and bottom, there is a small motor that is attached by screw(s). When the machine is turned on its intial position should be detected and if not , the sensor can be bad or the starting position is dirty or broken cable, or motor cables are bad, inspect them, reset the code and turn the machine off and back on.
Dec 21, 2008 | Riso RZ220 Duplicator
Riso Rz 220 copies are coming out to light.
1)You can set the dencity of the riso on the controll panel before you do your masters.
2)Always use original ink.
3)If you are a bit technical you can remove the pressure roller and strip all old ink buildup from it.was it with water ann soap.
If you open the drum and take it out completely,the pressure roller is the black roller inside the machine that put directly pressure on the drum.There is only one screw to loosen and then it hooked out,but it can be tricky to hook it back if you not doing it every day.
Oct 29, 2008 | Riso RZ220 Duplicator
Problem on Riso GR1700
Sometimes it is a one way pully inside the drum that is slipping.This is a mission to repair.
If you want to try it let me know.
Sep 30, 2008 | Riso RZ220 Duplicator
180 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
