Question about NEC DS2000 8 Slot Key System Unit (KSU) ( 80001) Phone
Trouble with NEC DS 2000 phone system
We've had the system for 2 years with no problems. However every evening at approx. 5 pm the system shuts down continually and the fllowing message appears on each phone:
"System Start Up In Progress"
This continues all night and we can't resolve the issue. During the "start up" no calls can be made ar received and calls in progress are lost.
2 Suggested Answers
  • 13 Answers
SOURCE: Red "call in progress" light will not go off
There is no such thing as a "Call In Progress" light on any NEC phone system. If you are talking about the Message Waiting light you will need to handle the message, or cancel the forwarding or do Feature 99 Feature.
Posted on Dec 08, 2008
How do i change the time
Depending on how old your system is try
To set the system Time:
1. Press the SPK key.
2. Dial 828.
3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM).
4. Dial two digits for the minutes (00-60).
5. Press SPK to hang up.
Mar 09, 2015 | NEC DTU 8-1 Corded Phone
How to change the month and date on nec dt300
Assuming that the standard numbering plan was used by your installer (SV8100/SV9100)
1. Press Speaker.
2. Dial 728.
4. Dial two digits for the minutes (00~59).
5. Press Speaker to hang up.
Mar 09, 2015 | NEC Lands Phones
Change the time on our NEC DT300 Series
What model of NEC phone system do you have? Go look in the phone or data room and look at the PBX. You might also be able to press Feature 3 to get some information which would be helpful to a tech. If it is an SV8100 try this:
1. Press
Speaker.
2. Dial
728.
5. Press
Speaker to hang up.
Oct 08, 2012 | NEC Lands Phones
What steps do I take to change the time on my NEC DTERM 80 phone system? I have already tried the Feature+9+# as well as the Recall+728 but those do not work. The first gives me an error message.
NEC Electra Elite IPK
  • 1 Press the "Feature" key on the phone system's main terminal. This is one of the Dedicated Feature keys and is located at the bottom left hand corner of the keypad.
  • 2 Dial 9# to enter the clock setting menu.
  • 3 Enter the hours and minutes using the key pad. For example, if it is 12:15, you would press "1," "2," "1," and "5."
  • 4 Press the "Recall" key on the bottom left hand side of the phone key pad to toggle between AM and PM.
  • 5 Press the "Feature" key to exit the system.
NEC Electra Elite IPK II
  • 1 Press the "Speaker" key located at the bottom left of the phone key pad.
  • 2 Dial "728" to enter the phone's clock menu.
  • 3 Dial the hour using two digits. Use military time for any time in the afternoon. For example, 1:00 AM would be "01," but 1:00 PM would be "13."
  • 4 Type the minutes using two digits ranging from "00" to "59."
  • 5 Press the "Speaker" button to set the time
Read more: How to Change the Time on an NEC Phone ' eHow.com http://www.ehow.com/how_7338757_change-time-nec-phone.html#ixzz1XUGjOOet
Sep 09, 2011 | NEC Dterm DTP 16D-1 Corded Phone
When the power is turned on the screen lights up for approximately 2 seconds then the power shuts right back off..... The batteries are good and even were replaced just as a precaution. What could our...
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
I understand you have replaced the battery... make sure its a genuine nintendo battery and charge. Also the port could be damaged or the ac adapter... take a good look at both for damages.
The port should not wiggle on the DS and should be solid.
Jun 29, 2011 | Video Game Consoles & Games
Cant change time on nec etw phone
Try this:
NEC Electra Telephone System
Changing the time on a Electra Elite & Professional system must be done from the "main" or primary phone. It is usually extension # 100. 1.- Press "FEATURE" 2.- Dial "9#" 3.- Enter hour and minute 4.- Press "RECALL" to change AM/PM setting 5.- Press "HOLD" to change the calendar setting 6.- Press "RECALL" to change the day of week 7.- Dial "#" to move the cursor to day of month field 8.- Enter day of month 9.- Press "RECALL" to select month 10.- Dial "#"to move the cursor to year field 11.- Enter last 2 digits of year 12.- Press "FEATURE"
Carl
Nov 06, 2009 | NEC Electra Professional ETW-16DC-2
Display clock on phone
I found the answer at www.digcom.com.
CLOCK/CALENDAR SETTING
Note: The date must be set in system programming (10-01).
1. Press the Speaker key.
2. Dial 728.
Aug 05, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Cleer ID display on NEC Ranger DK824 telephone system
I have a DK824 I bought in 2000 which did not have called ID capability - that was explained to me on purchase - if yours is 2 years old they must have kept the models the same for a long time though
Jun 25, 2008 | Lands Phones
Need help with re-setting time, date etc - haven't got a user guide or manual
If your telephone system is an NEC IPK, Pro II, or Elite, you should be able to go to extension 100 or 101 and dial Feature 9 and enter the new time. To switch between am and pm, press the Recall key after you enter the new time. If your extension numbers do not include 100 or 101, this should work from the 2 lowest extension numbers. The type telephone you have can be used on other NEC systems, and these instructions will only work on the ones I listed above.
Dec 01, 2006 | NEC Dterm DTP 32D-1 Corded Phone
Need user guide or manual to set time, etc
NEC Electra Telephone System Changing the time on a Electra Elite & Professional system must be done from the "main" or primary phone. It is usually extension # 100. Press "FEATURE" Dial "9#" Enter hour and minute Press "RECALL" to change AM/PM setting Press "HOLD" to change the calendar setting Press "RECALL" to change the day of week Dial "#" to move the cursor to day of month field Enter day of month Press "RECALL" to select month Dial "#"to move the cursor to year field Enter last 2 digits of year Press "FEATURE"
Dec 01, 2006 | NEC Electra Elite 32D-1 Corded Phone
NEC DS2000 8 Slot Key System Unit (KSU) ( 80001) Phone Logo
202 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
