Question about Microsoft Xbox 360 Console
Xbox 360 Static
Hey guys i get static on my xbox 360, it looks like it snowing. the dashboard is fine but once i get to gameplay is when it does it. but the menu of the game im playing is fine, its just when gameplay is going. i have it hooked up to the HD component cables into my TV.
Same thing happen to me today, exact same thing on cod4 then i got the E-74 error code.. i thought it was my HDMI cord so i put in the orginal HD component cables.. turned it back on then i got the error message E-74.....the best thing to do is call mircosoft or go online and set up a fixer....becuase there is nothing to do... overheating it with towels works for a while maybe an hour or so then it's the same MATRIX lines... turn it off then the error message appears...if your handy and trust yourself or impatient then take it apart...its ton of videos online to help you...as for me ill wait...but it really sucks since madden comes out in an hour:(...good luck!!!!!
Posted on Aug 12, 2008
SOURCE:
Xbox360 Recording Problem (With DVD Recorder)
FixYa, stop asking me to fix Xbox 360 problems, I DON'T OWN ONE NEVER HAVE. Also I don't care about other people's problems, just mine.
Apr 06, 2014 | Microsoft Xbox 360 Console
Connection to winows media failed
1. check your netwok calble properly
2. check your router internet connection
3. follow these steps
Accessing network settings loadTOCNode(2, 'moreinformation'); To access the Network Settings area, follow the steps for the version of the Xbox 360 Dashboard that you are using.
New Xbox Experience Dashboard:
  1. From the Xbox 360 Dashboard, select System Settings in the My Xbox area.
  2. Select Network Settings.
  3. Select Configure Network.
Legacy Xbox 360 Dashboard:
  1. From the Xbox 360 Dashboard, move to the System blade.
  3. Select Edit Settings.
IP settings, IP address, subnet mask, and gateway loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this imagenetworksettings-basic.jpg
After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the IP Settings block, you are prompted to select an Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your IP settings from your network or from your modem or Internet service provider (ISP). This option is recommended for most users.
You may have to or prefer to manually configure the IP settings, especially when a static IP address is used. This is necessary only if your ISP has issued a static IP address, or if you have configured the router to issue static IPs (and DHCP is not used). To manually configure the settings, select Manual, and then enter the IP Address, Subnet Mask, and Gateway by using the keyboard on the screen. When the information is complete, select Done.
DNS settings, primary and secondary DNS servers loadTOCNode(2, 'moreinformation'); After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the DNS Settings block, you are prompted to select Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your DNS settings from your network or from your modem or ISP. This option is recommended for most users.
You may have to or prefer to manually configure the DNS settings, especially in scenarios in which a static IP address is used or where DHCP is not available or not offered by the ISP. To manually configure the settings, select Manual, and then enter the primary and secondary DNS server names by using the keyboard on the screen. When the information is complete, select Done. Note You do not have to enter a secondary DNS server to connect to Xbox LIVE. A secondary DNS server is required only if the primary DNS server has technical problems.
Wireless settings loadTOCNode(2, 'moreinformation'); To configure your Xbox 360 console to connect to your wireless network by using an Xbox 360 Wireless Adapter, follow these steps:
  1. Access Network Settings .
  2. On the Basic Settings tab, select Wireless Settings.
    Note If the wireless settings area does not appear or is unavailable, click the following article number to view the article in the Microsoft Knowledge Base: 909333 (http://support.microsoft.com/kb/909333/ ) While attempting to view the settings for a wireless network connection, all the wireless functions appear to be disabled in the Xbox Dashboard
  3. Follow the instructions to select your wireless network, select your wireless network name, and then enter your wireless security information.
  4. Select Done.
PPPoE settings loadTOCNode(2, 'moreinformation'); If your Internet service provider uses PPPoE authentication, you have to enter the settings in the Xbox Dashboard if you have a direct connection through a modem. If you use a router or a gateway instead, leave the PPPoE settings blank because the router performs PPPoE authentication. Note If your ISP does not use PPPoE authentication, make sure that these settings are blank. To learn whether your ISP uses PPPoE authentication and to learn the correct PPPoE information, contact your ISP.To configure the PPPoE settings on your Xbox 360 console, follow the steps for the version of the Xbox Dashboard that you are using.
New Xbox Experience (NXE) Dashboard:
  1. Move to the System area of the Xbox Dashboard by using one of these methods:
    • Press the Xbox Guide button on your controller to open the Xbox Guide, scroll to the right to access Settings, and then select System Settings from the list of options.
    • Select the My Xbox channel, and then scroll to the right to select System Settings.
  4. On the Additional Settings tab, select PPPoE Settings.
  5. Use the keyboard on the screen to enter the PPPoE information that was provided by your ISP.
  6. Select Done.
  7. Select Back to return to the main Network Settings area.
  8. Select Test Xbox LIVE Connection to restart the test with the new PPPoE settings that you have configured.
sure it will work thank you
Mar 14, 2010 | Microsoft Xbox 360 Console
How do i set up xbox live
  4. Select Done.
  6. Select Done.
Feb 11, 2010 | Microsoft Xbox 360 Elite Console - Black
Better online gameplay xbox 360 open nat type
Hey to open your NAT log into your router and look for a setting called DMZ enter your xbox IP (usually starts with 192.168.1.?) into the DMZ box and enable it.
Good Luck & Game on!!! :)
Jan 25, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Once the xbox is turned on, the picture will freeze with static lines and the only way to clear it is to turn it off and back on. sometimes happens even in the dashboard area.
Yes this normally happens before you get the 3 red lights error, it means that the motherboard is warping because of the heat, and you will need to get it fixed.
You can send it in and they will fix it for you or if you dont want to wait you should use an Xbox 360 Repair guide that works!
Nov 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 static lines no picture, but sounds,
Log in to your XBox live account and sign up to return your box for service. Even if it is out of warranty Microsoft has been fixing them for free including covering shipping. Our box just went through, took 11 days total.
Jun 21, 2009 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Xbox 360 flickers across screen
it is your av cable however the components in the cable get a small static boost when u are using your controller so it becomes an intermittent fault ie;....when in game vidios or watching dvds, u rarely use the controller so u dont see the flickering and u only see it when in game play because u are in constant contact with the controlls and the components inside the av cable recieve a small static boost causing the interference.
Oct 07, 2008 | Microsoft Xbox 360 Console
My xbox 360 has some static.
mine doesnt even play games. maybeif i take a **** in the disk tray....
Apr 24, 2008 | Microsoft Xbox 360 Console
Change NAT to open
I don't have your Internet connection details or OS
so we'll start from the beginning:
1.Log into the router and under the Setup tab click on "Setup Wizard" then on the next page click on "Launch Internet Connection Setup Wizard" In step 1 leave the password unchanged and click next. On step 2 select your time zone. On step 3 this is important; select your Internet connection type. On the 4th step leave the Address Mode in Dynamic and enter the username and password supplied to you.
Once you have configured your Router to work with your Internet connection type, you should now get a Moderate reading when you do the Network test in the Xbox dashboard.
2. Now go here http://www.portforward.com/networking/static-xp.htm and follow the instructions to setting up a static IP address on your computer.
3. After setting up a static IP address on your computer, go here http://www.portforward.com/english/r...x_Live_360.htm and follow the instructions. Something you should keep in mind which isn't mentioned on this page is, for each port you forward under the box that says "IP Address", don’t put the IP address of your computer, you put in the new IP address of the Xbox 360 which was one of the 5 that was generated from that link in step 2. What you are doing is giving the Xbox 360 a new IP address and that new IP address needs to forward these port numbers to the Router.
4. Go into the Xbox dashboard and edit the Network settings. Under Basic Settings click on IP address and set it to manual. Now enter in the new IP address you chose for the Xbox 360. The subnet mask and the gateway is the same as your computer. (You can find these by clicking start> run> type in ‘cmd’ then when the box comes up type in ipconfig/all
Under the DNS Settings it should be set to automatic and under Additional Settings leave them empty. Run the test in the dashboard and it should now be Open!
Feb 23, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
