Question about Pioneer CDJ-200 CD Player
Pioneer cdj 200
I put the power cord straight into the wall,now have no power,what can i do?
  • 1 more comment
  • shaz_pn Sep 22, 2008
    i have the same problem
  • Silahh Nov 30, 2008
    What can u do when the fuse blow off?
  • DJ_Destiny Mar 13, 2009
    After u replaced the fuse did it work?
The fuse was blown inside!!
Posted on Aug 12, 2008
Manual for a pioneer cdr 200
www.manualslib.com/manual/699716/Pioneer-Cdj-200.html#manual this is a good choice for finding your information. www.manualslib.com in the seach box enter Pioneer-Cdj-200.
Nov 24, 2017 | Pioneer Audio Players & Recorders
CDJ-200 keeps ejecting disk without reading it. Tried to clean with a disk, and with compressed air, but it's still ejecting any CD that I put into it. It was working fine while I was mixing, and then just...
hii there,
Please also let me know if u get any error msg too. If dont get any
error msg. Please try to clean compartment of ur CDJ. But you have to open ur CDJ than clean it. If it does not work again. Then ur
CDJ need adjustment or alignment.
thx,
djajay
Aug 09, 2010 | Pioneer CDJ-200 CD Player
CDJ 200 meant for US mains supply plugged directly into UK mains supply, now don't work. Replaced external fuse but still don't work..anything else i can try before i bin it?
Dont bin it!!!
If you are really lucky it may have just blown an internal fuse or if your not so lucky it may have killed the mains transformer which is still worth repairing.
If the transformer is faulty and was replaced with one sourced from Pioneer GB then no external 240V to 110V transformer would be needed - you would be able to plug it straight into a UK mains supply.
Jul 20, 2010 | Pioneer CDJ-200 CD Player
I have a CDJ 200 cd player the power when turned on there is no display YASH
Hi Yash,
pls make sure and check the fuse of your CDJ. Also check the power output that is 240v or 110v.
thx,
djajay
May 25, 2010 | Pioneer CDJ-200 CD Player
No audio on cdj 200 after a power failure
check the fuses to see if they are any good
Feb 17, 2010 | Pioneer CDJ-200 CD Player
CDJ-200; Only the power button works, nothing else.
I have the same unit accept mine was 1000, mine did the same thing, im fairly electrical incline, but its much more complicate trying to fix it your self, I can recall contacting the manufacture and they had me ship the unit to closet authorized dealer and have it repair. If it still in warranty, you need to contact them asap. 1 (866) 214-1310
Sep 01, 2009 | Pioneer CDJ-800 Turntable
Pioneer cdj 200 wont read discs
Hi, try cleaning the lens with a cleansing disk. if this doesn't produce results, it will confirm a major issue within the lens assembly. you will need to replace the lens assembly in this case. it is unable to track or read in this damaged sate.
May 19, 2009 | Pioneer CDJ-200 CD Player
CDJ 200 without electricity fuse blow off?
no you cannot do that , the device works on 120v( 117v around me) , but it cannot be changed like that , you would need a trans former that breaks down the voltage to 120v
changing the fuse will not change the circuitry in the device
Nov 30, 2008 | Pioneer CDJ-200 CD Player
Moved by royal mail and now wont turn on
i have the same problem...did u solve it?
Jun 24, 2008 | Pioneer CDJ-200 CD Player
Pioneer CDJ-200 CD Player Logo
450 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
