Modem and router
The power and pc/activity only light up, and i took all of the cables off and put them back on, and still the only those lights are on, and i try to turn off the modem but nothing happens.
  • 19,396 Answers
If there is no network or internet activities it means either network is down from ISP, or there is a phone line cable or broadband filter problem, or broadband settings on modem are lost and must be reinstalled.
Usuall you fix this kind of problems by calling your Internet Service Provider toll free customer tech service number.
They will follow you step by step in fixing the problem.
Posted on Aug 12, 2008
I have a SB5101 modem, I rebot the modem and now it doesn't work , just the power light and the pc/activity(ambar) are working what i should do?
Try this unscrew the cable from the back rub your finger over the center and the side of the cable.Unplug the modem for 20 seconds plug the modem back in and immediately put the cable back in.
I can explain how this works but would take to long.
May 04, 2012 | Arris SURFboard® SB5101 Cable Modem
My dsl internet light stays red when plugged into the router, but okay when plugged into my computer
print2.gif print email2.gif email
Title: Setting up Cable Internet for the RV082 Article ID: 16585
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is assigned a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys router to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a router to copy the MAC address of the PC that's registered with the ISP.
NOTE: Before proceeding, use the computer that can go online when connected to the modem and follow the steps below.
Step 1:
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your ISP. If it can go online, the PC connected to the modem is the one that's registered with the ISP.
kb16585_001_en.png NOTE: The image may vary depending on the computer and modem you're using.
Step 2:
Once an active Internet connection is established through the modem, connect the modem and the computer to the router by following the instructions below.
Step 3:
After ensuring that you have an active Internet connection, connect the modem to the router's Internet port and the computer to any of the four Ethernet ports.
Step 4:
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router. For instructions, click here.
Step 5:
Access the router's web-based setup page. For instructions, click here.
Step 6:
Go to the Setup - Network, click the drop-down arrow under the WAN Connection Type field and select Obtain an IP automatically for WAN1.
kb16585_002_en.png NOTE : If you are going to have another Cable Internet as well in WAN2, select obtain an IP automatically as well.
Step 7:
Click Save Settings.
Step 8:
Check in the System Summary if the router is getting a WAN1 IP or WAN2 IP.
NOTE:
If there are no IP addresses seen in this field, go back to Setup then click the More option to reveal the MAC Clone settings.
Step 9:
Select MAC Address from this PC.
Step 10:
Click Save Settings Button.
Step 11:
Click System Summary. Check the value of the WAN1 or WAN2. If these have numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're not online, perform a power cycle to synchronize the router with the modem.
kb16585_007_en.png NOTE: If the WAN1 IP or WAN2 IP is all zeroes (0.0.0.0) click first Release then click Renew buttons. If the WAN1 IP or WAN2 IP is still all zeroes (0.0.0.0) perform a power cycle.
If the IP Address starts with 192.168.1.xxx or if it has the same first three numbers (octets) as the router's IP address, change the router's LAN IP address to a different LAN segment.
Step 12:
Once the router is configured, perform a power cycle. Shutdown the computer and Unplug the router's power cable. Unplug the Broadband modem's power cable and wait for 30 seconds then plug in the Broadband modem's power cable and wait for its lights to appear stable. Plug in the router's power cable once the modem's lights appear stable.
Step 13:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router. For instructions, click here .
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 25, 2010 | Linksys RV042 VPN Router
Whenever i set it all up and turn it on the modem light blinks orange, how do i fix this?
The initial Step kindly check all the lights are glowing in the Modem,If it glows then follow the below steps,
1.At the back side you will have a reset button,hold it for 30 secs and the lights in belkin router starts blinking
2.type in the internet explore 192.168.2.1,
3.Click on "Connection Type" at left side,it asks for password leave it blank and click submit
4.Select the Type as Dynamic and click on next
5.Click on Apply changes,Router gets automatically rebooted
6.Click on "MAC Address" at the left side and then click on "CLONE" and then click on Apply Changes
7.Unplug the power cable from modem and router
8.After 5 secs put the power cable only to the Modem and wait until all the lights in modem gets lit up
9.After that put the power cable to router,check you will see all the lights in the router(Modem,internet,power)
Regards,
Ayysam
Dec 06, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wired, router, modem and internet light comes on but i am not allowed to browse...why is that? if i connect the modem directly to the pc then i can browse just fine...
Well , the problem is with the router , we can powercycle the complete network and if that does'nt work then router's setting's has to be re-configured.
Steps to powercycle the network:-
1)Turn off or shut down the computer.
2)Take the power chord out from the router.
3)Take the power chord out from the modem and the wait for 60 to 90s.
4)Plug the power back to the modem first and wait until all the lights gets stabilized on it.
5)Once the lights get stabilized then Plug the power back to the router and wait for the lights to get stabilized.
6)Turn on the computer and it might work else re-configure the setting's of the router.
Nov 23, 2009 | Computers & Internet
My Pc Activity light in constantly blinking and my
Router, depend on the model but it sounds ok
try 2 things - sounds like a bug
turn off system restore
google & download
  • combofix
  • dailafix
run both of these and then restart
turn on System restore
I think you should find it faster now
Richard
Nov 12, 2009 | Computers & Internet
Only the power light is on.
double check your cables and replace if needed with a good cable connected from your modem to the wan port you should get an active light on your router. If you don't get activity with a good cable the router may be pooched or the power supply for the router is dying.
Aug 12, 2009 | 2wire Computers & Internet
Belkin F5D7230-4 not working anymore?
Well i think u r right, u must contact to Belkin support team (http://www.belkin.com/support/) or to from where u buy this. If router is in warranty period then u will get replacement.
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
Unable to set 2wire wireless connection with my PC
connect a cable modem to it take out thwe existing ethernet in the cable modem put in the 1 that u have with ur new 1 put it in the cable modem put the other end in the first port of the ethernet ports take the 1 u took out of the cable modem and and it put it in 1 of the thernet ports all the light should go green then try wireless.
Feb 25, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Motorola sbg900 wireless modem
have you tried powercycling your modem? turn of your computer, unplug the power cord from the back of the modem. wait a minute (literaly). plug power back into modem and wait for lights to come on and stop flashing. power computer back up. Check to see if connections works. Also check your cable connections between the modem and the computer. If all fails contact your Internet Service Provider, who most likely provided you with the modem.
Apr 08, 2007 | Arris SURFboard SBG900 Wireless Router...
Netgear fr114p constant activity problem
Have you looked at the traffic logging information from your FR114P? You might want to visit http://www.LinkLogger.com and download a copy of Link Logger for your firewall and see what your firewall says is hitting it. Do You have UPNP enabled in the router ?
Feb 19, 2006 | NetGear FR114P Router
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
