Question about Oregon Scientific WR102 Weather Radio
I have an oregon scientific model #wr601n noaa weather radio. I have the instructions, but can't find how to unlock it. I locked it, but have no idea how I managed to do it, frustrating!
Ok this is how i fix it press channel and vol up not at the same time first channel and the vol up
Posted on Aug 23, 2012
    New Friend:
Pressing the Channel button then releasing it, then immediately press the up volume button toggles lock/unlock. It would be nice if they included this in their instructions.
Posted on Apr 27, 2015
3 Suggested Answers
SOURCE:
SOURCE: Wr601N Oregon Scientific radio locked
Oregon scientific locked, meed to unlock
Posted on May 26, 2011
SOURCE: Lost the instructions to program my weather radio.
Just follow the link below. I just this PM downloaded it for the same reason. All you need is Adobe Reader to read or print it: http://site.ambientweatherstore.com/Manuals/wr102.pdf Regards, Craig Starr Danville, NH 03819 dts_cjs@hotmail.com
Posted on Feb 13, 2007
I have a Oregon Scientific weather radio. I have lost instructions and am try to figure out how to set alert status by counties.
From the Oregon Scientific site top ten questions: click the link below to download the manual for the model number of your radio:
Manuals XF
Apr 08, 2015 | Oregon Scientific Audio Players &...
Cl-935
This model number does not appear to relate to Oregon Scientific. Look at these two manuals: they may answer your question: http://www.manualslib.com/products/Oregon-Scientific-Eb313hg-294871.html
Aug 03, 2014 | Oregon Scientific Handheld Weather...
How do I disable the alarm on my wr602 weather radio?
The trick was to press the power button (the circle with a line through its top) on the very top of the device until neither NOAA by itself, nor NOAA together with that power
button icon are showing. Then press Menu until one of the alarms shows up. Then use the up or down arrows until -:-- shows; that indicates the alarm is disabled. Then
choose exit. The bell for that alarm should disappear.
It kind of makes sense that you do not want to be dealing with NOAA in any way, since the clock is totally separate. It would have been nice if the manual had explained this.
Jul 03, 2011 | Oregon Scientific WR108 Weather Radio
May 15, 2010 | Midland WR-100 Weather/RDS Radio
Oregon Scientific Weather Station
Choose the appropriate model from
http://www2.oregonscientific.com/service/manual_downloads.asp?t=3&cid=2
Apr 15, 2010 | Oregon Scientific Lwb0997110113004...
Has the Oregon Scientific WRS101 been recalled?
It looks like some models were recalled. Go to this site and see if your radio still qualifies for the recall, it looks like your model number probably does.
http://www2.oregonscientific.com/recall_form.asp
Apr 02, 2010 | Oregon Scientific WRS101 Weather Radio
My Oregon Scientific WR602 frequently loses it's settings and I have to reset it before it will pick up the NOAA again. Once I do that everything is fine for a while, then it loses it's settings again and...
It happens, and can be discouraging at times. Not sure what your locale is, but there are certain geographical areas that are more equipped with towers to create a more stronger and consistent signal, whereas there are also areas that have less towers that create a weaker signal. If you are noticing that your WR is frequently losing a signal, or are receiving consistent white noise/static, you might try moving your WR device into a different location. It may take some test time at each location.
Here are some other tips:
1) Make sure your WR is placed in a location away from the use of too many electrical devices. Sometimes, just plugging your device away from your computer, desktop telephone, answering machine, and other electrical devices will frequently solve the problem.
2) Try stationing your device to a higher location. If you have a 3 story home, consider placing it in the upstairs. Same applies with lower levels. If you have a one story home, try stationing your weather radio higher up and test your signal then.
3) Make sure that your WR is capable of receiving a signal. The best signals are typically reached when the receiver is placed near a window with no visible interference blocking the transmission.
4) Make sure your battery is charged or unit is placed in the charging base to receive a solid signal.
5) Make sure your location and channels are set correctly. If you set your location to AUTO, you should have no problem hearing weather reports for your area. If you would like to hear the weather report for your county only, call 1-888-697-7263. Follow the prompts through a simple voice menu.
(OR) go to www.nws.noaa.gov/nwr/indexnw.htm. Click the state for which information is needed.
Oct 30, 2009 | Oregon Scientific WR602 Weather Radio
I am looking for the user guide for an oregon scientific weather radio model wr602
http://www2.oregonscientific.com/service/manual_downloads.asp?querystring=wr602
Aug 06, 2009 | Oregon Scientific WR102 Weather Radio
Feb 13, 2007 | Oregon Scientific WR102 Weather Radio
Oregon Scientific WR102 Weather Radio Logo
3,781 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Gyula Lacz
Tom Chichester
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
