Question about Zanussi ZWF1440 Front Load Washer
Zanussi 1431 - All lights flash when push any button.
Hi - we had a storm lights flickered. Now machine has the program selected - 155 mins on the display but when I press start (or any button) all the lights flash and it beeps for a couple of seconds but nothing happens?
Any help is much appreciated!
Best regards,
Richard.
  • richiepp Dec 01, 2008
    Hi - Just to update the group. I ended up calling the repair man (luckily was still in guarantee by 3 days!) and he had to replace the controller. Thanks - Richie
    Champion:
  • 249 Answers
Leave it unpluged for one hour,then try again
Posted on Dec 01, 2008
  • eamonn close Dec 02, 2008
    Good for you lucky,close Ireland
Zanussi 1116
I would call an appliance tech. This definately is an advanced issue required by a tech to diagnose.
May 06, 2012 | Washing Machines
ZANUSSI FLE1015W,THE problem i have is that once i turn on the machine and press fabric button the program lights come on and the start/pause button light flashes i press the start/pause button a sound is...
Have you selected a program?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Zanussi FLE1416W Front Load Washer
Hi, I have a Zanussi Timeline 1400 front loader and after it has completed a wash, it will not do another wash for some time. If you select a program it will think about it and then say it is complete with...
Try this..
Reading Error Codes
1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up.
Jan 30, 2011 | Zanussi ZWF1450W Front Load Washer
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
My zanussi 1400xc washing machine won't start its cycle. The lights are all on in the correct settings, but the start button continues to flash and wont start the cycle. I have cleaned the...
unplug for 40 minutes to reset the ECU. If still doing the same - replace the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Our washing machine (Zanussi ZWF 1632 W) flashes 5 times
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Dec 11, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf1237w washing machine
I had the same problem my 3 yr old had been playing with the buttons and the whole thing just locked up and displayed ERR no amount of unplugging turning off would fix it.
Till ...........
  • Take off the top
  • Unscrew front panel and remove,
  • Then remove circuit board from panel,
  • Desolder the square battery,
  • Leave to stand around 15 Min's, (would recomend longer to be sure)
  • Re-solder Battery refit circuit board and refit panel.
This discharges the program memory chip and resets to default.
Hope this helps it's not so hard as it sounds just take care with the battery. DON'T put to much heat on it use a screwdriver on the small connections to act as a heatsink.
Nov 22, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
215 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
