Question about Sharp AL 1631 Copier
H4 on the screen
I tried what you just recommended to the previous question and the clear, copy, clear, copy didn't work. How else can I reboot the machine?
  • Sharp Master
  • 2,794 Answers
H4 is an error code for the fuser roller. If the clear code doesn't work, you probably have to get the thermistor replaced in it and have the whole fuser looked at.
Posted on Aug 12, 2008
H4 ERROR CODE
press on the keypad, # * C * the machine will enter a diagnostic mode. Then enter 14 as if to make 14 copies. You may then have to press 1 and execute the program. But that will clear the H4 code 99 percent of the time. Once you enter 14, just press start and follow the directions on the screen. An H4 means the machine was just slow to warm up. It can be a fuser error, but there actually being a problem is extremely rare. Performing a clear 14 will almost always clear that.
Feb 22, 2011 | Sharp AL 1631 Copier
Blinking a printer screen number h then 4
press on the keypad, # * C * the machine will enter a diagnostic mode. Then enter 14 as if to make 14 copies. You may then have to press 1 and execute the program. But that will clear the H4 code 99 percent of the time. Once you enter 14, just press start and follow the directions on the screen. An H4 means the machine was just slow to warm up. It can be a fuser error, but there actually being a problem is extremely rare. Performing a clear 14 will almost always clear that. It may also be P * C * to enter diagnostics.
Feb 22, 2011 | Sharp AR-M205 Copier
H4-01
H4-01 is an error code that the fuser temperature is too low. This can be caused by a number of things, such as the copier wasn't given enough time to warm up, or the room was cold. You can reset this code by entering simulation mode. #,*,C,* Then press 14 and copy button. Reboot the copier, and this should clear the code.
Sep 27, 2010 | Sharp AR-M350U Copier
Call for service: h4-00
H4-00 means thst the copier isn't warming up quickly enough. Try this code to reset it. Press the following buttons in this order: #, interupt, C, interupt, 1, 4 . machine will say sim 14 trouble clear are you sure. Press the OK button. This should reboot the copier. Most likely the machine is in need of a heater lamp in the fuser unit.
Sep 20, 2010 | Sharp AR-275 Copier
Probleme code H4
Press # * C * , that will put the machine into diagnostics.
Enter the number 14 as if you were making 14 copies. Then follow the screen directions to clear the fault code. Should be enter 1 then press start.
The machine will reset and should be fine.
Jul 21, 2010 | Sharp AR-5320 Black and White Copier
One number of photo copy machine drum cartridge wasinstalled. It worked once. Now machine is showing letter H and 4 flickering alternatively on the screen. Because of this none of the function of machine...
This code is almost always a false code. I would try clearing it by entering the following key sequence:
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" (Note that the exposure mode key is the far left key and that these 4 keys must be pressed within 4 seconds)
The display should have gone blank if these 4 keys were pressed properly.
Now enter 14 as if you were making 14 copies then press the Print Button.
This should clear the H4 code and the machine should operate normally.
If not and the H4 comes back then you have either a thermal fuse or heater lamp failure.
Good Luck
Nov 10, 2009 | Sharp AL 1631 Copier
How to solved code H4 Xerox Xc1245
This code is akmost always a false code. I would try clearing it by entering the following key sequence:
Good Lucj
Nov 09, 2009 | Xerox XC356 Copier
Copier trouble
press clear , exposure , clear , exposure : the machine will switch off
input 14, press start and the machine will reboot.
this will proberly solved your problem
Apr 28, 2008 | Sharp AL 1631 Copier
Sharp AL-1631 copier problem
press copy. clear, copy, clear.( you have to press it fast )
the machine will switch off and then press 14 then start.
the copier will reboot to its normal state.
H4 Problem
Hi there, if you want to clear this code its very simple, do the following: -on your control panel locate the clear and auto exposure buttons, next -hit in the following sequence clear, auto, clear, auto without holding them down, after that all your panel lights should go out. If they do not you have to keep trying...They will go out. -Next program the machine as if your going to make 14 copies -Once 14 is displayed, hit the green start button and your copier should be working again. Cheers! :)
Sep 11, 2006 | Xerox WorkCentre XE88 Laser Printer
Sharp AL 1631 Copier Logo
102 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
