Question about Mitsubishi VS-50605 50" Rear Projection Television
Power supply i recently posted that i needed a to buy a power supply for the mitsubishi vs-50605 tv. this is what i tv repair told me i needed. what i should have do is posted the problem i was having and comparing it to the repairmans assesment. when i press the power button on the tv the power light comes on for a second and it turns off right away. it sounds like a breaker is tripping off on the inside of the tv. any suggestions? thanks
  • mwfone Aug 13, 2008
    I have the same exact problem. Turn it on and goes right off. No extra blinks or anything. Cannot turn it on from the remote. It has new batteries.
  • m23s Aug 23, 2008
    I have the exact same problem. The repairman on the phone told me it could be capacitors or power supply. And he said, if it cost more than $300 dollars to fix, go buy a new TV.
  • 927 Answers
Good Day,
Why not try to fix it, it's hard to find a board and easier to repair. Try these; 1). CHECK IC700 PIN 20 (AC-OFF) FOR 0 VOLTS DC. IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2).
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Aug 30, 2008
Shaky picture once warms uphorizontal lines stream through it continuisly
there are some capacitors on the signal board that are associated with the pwer supply regulators off the 5 volt and other sources there that need to be replaced
if you have the tools and know how and soldering station you can do the repair your self if not then you might want to contact a servicer in your area
i can get you the cap location numbers if you like
Oct 24, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Power suplly
This model is famous for capacitors being bad in the low voltage regulators on the signal board. Also has been known for cold solder connections in the power supply to the convergence IC. I don't have my notes at home but I belive that model only uses one IC for convergence, STK393-570. You cant see it from the back because of it being hidden by its heat sink.
Jul 15, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi Vs-50605 TV dead
First thing on a Dead VZ7 to check is the solder connection at the yokes "DY" Connector. Then Check C411 2200uf @ 35V
Then C412 10uf @50V. Then Check IC700 Pin 20 for 0VDC any voltage other than 0VDC on that pin means Diode D980 is leaky.
Hope this helps. If you need anything further let me know.
Jan 15, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs-50703
NO POWER===Check all fuse devices on PS PCB. Shorted convergence IC's will cause that== change IC's.See what you have-let me know what you find.
Oct 01, 2007 | Mitsubishi VS-50605 50" Rear Projection...
VS-50605 Screen
might measure the opening and buy a piece of plexiglass, wont look quite as good, but cheaper than a new one and usually available at glass shop.
Jul 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Timer light flashes 3 times
the code means that your tv power supply is not functioning your tv needs to be repaired call the tech.good luck
Apr 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
