Question about Xerox Office Equipment & Supplies
Fuser lamp on xerox model XC1255 needs replaced
    President:
  • 2,072 Answers
Are you asking directions or where to order.
Anyhow, Either way, google "the parts drop".
Call and ask for Britt, he will have the part at a fair price and
most likely can send you directions.
I don't work there, just have done business with them for years.
First class business.
Posted on Aug 11, 2008
I have a problem of fuser module (r3) temperature error in xerox workcentre 5755
Can you feel any physical heat from the fuser. Sounds like either the thermistor that controls temperature or the lamp failed.
Sep 15, 2016 | Xerox Office Equipment & Supplies
Xerox DP C2255 Fuser temperature needs to be changed, is there anyway i can do this without having to involve xerox tech's coming out? Issue is the toner wont fuse to the paper properly, fuser was...
If it's not melting the toner then the fuser assembly is bad again or it isn't getting the proper voltage for the heat lamp to melt the resin toner. Also could be the rubber roller that pushes the heated toner into the paper but that is generally part of the fuser assembly.
Jul 19, 2011 | Office Equipment & Supplies
My xerox FaxcentreF116 is displaying a message "printer Error Fuser warming" ant it dose'nt do anything any one can help?
you wil need to replace the fuser or open the fuser and look at the thermosta and thermoster.for dirt and continuity. clean or replace .But make sure the lamp is not broken also and be very carefull it get hot and there is sencetiff parts in the.
Jun 11, 2011 | Xerox FaxCentre F116 Plain Paper Laser Fax
Multifunction /Copier/Scanner Laser Printer Printer Error Fuser Temp. in xerox 3100mfp
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Then replace broken part.
Sep 15, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Hi i have a Xerox work centre workcenter m15i which when it turn on, it display heating Error.what could b the problem.assist
Heater quarz lamp is blown/cut. You can access it by removing the right side back vertical panel, removing a connector and four screws. You can pull the whole fuser assembly out very easily.
There is no spare part for the lamp itself. You must replace the fuser unit (which contains the lamp + thermostat).
Sep 15, 2010 | Xerox CopyCentre C20 Black and White...
@ wheatlandsvc: Can you recommend a service repair person in Seattle who can order and install parts for the XC1255? My printer also jams halfway through a print, and the toner on the jammed paper is not...
I am sorry, I can not. I can however make some suggestions.
I would look in your local yellow pages under copier service or copiers in general. Try and find an independant service company or single individual. Specifically you can ask if they have any experience with either your Xerox XC1255, or with the Sharp Z series. Your Xerox is a Sharp Z 800 series copier with Xerox's name on the front. If your issue is the gear which is very likely then they are readily available from Precisionroller.com part# H5100 or they can Google search for Sharp Part# NGERH0540FCZ3
A good price range for this repair is in the $100 range parts and labor.
Hope this helps
Nov 18, 2009 | Office Equipment & Supplies
Xerox model # XC1040 flashes H4 when turned on will not make copies ? code
H4 is a fuser error code. it basically means that the fuser is heating up. from what i can see the fuser lamp alone will be about $60.00. that would be the best case scenario if the rest of the fuser parts are ok. the upper fuser roller is 135.00 and lower 144.00.
Oct 16, 2009 | Xerox Office Equipment & Supplies
Xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Jan 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Replace Fuser Gear Xerox XC1040 Copier
Call a tech!. You first remove fuser assy from machine. One green screw to loosen and then you figure the trick out to get it out. Then once its out remove cover 2 screws I believe. Remove the lamp gently, you can do this with out unscrewing anything. Then remove the little clip on end of heat roller, simple spread clip and replace gear. It takes a tech about 10 min.
Feb 13, 2008 | Office Equipment & Supplies
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
