Question about Nikon D50 Digital Camera with 18-55mm Lens
Nokkon D50 showing err on ctrl panel
While clicking camera makes a small sound and it is not focusing.
Following stepd down
1. Battery removed fully charged and tryed no luck (Battery Original)
2. Lense contact cleaned by alcohol
3. several time pressed bottom reset button
4. SD card formated and several time inserted and released and tested no joy
Please any body can help
Try this. I own two D50's.
Move the settings to manual on the dial and the lens.
Take out the lens
Take two pictures.
Replace the lens.
Move to automatic position on the dial.
Hopefully the error has gone away.
Guy
Posted on Dec 27, 2008
    Problem Solver:
  • 9 Answers
Try ensuring the AF switch is set all the way (On camera AND lens). I had mine partially turned on once and it made a noise and wouldn't focus. I probably caused damage from it too (I pray I did not). But if that's not the problem, my best guess would be that your autofocus motor is shot. If that's the case, you can either put it in for repairs or switch to manual focus and focus everything manually (which isn't really too bad, is it?)
Posted on Nov 20, 2008
It seems to be focusing, but the pictures are blurry - lens is clean, same issue when auto focusing or manual focusing. Doesn't seem to make a difference if I hold the shutter down only halfway to give it...
Please make sure that you're using fully charged battery pack.
Remove the battery and reinsert after 1 minute.
Reset the camera by following the reset procedure from the manual of the Camera.
If the issue persists again, service is required
Dec 31, 2010 | Kodak EasyShare M530 Digital Camera
My canon eos rebel xti keeps showing error code 99
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Nikon D50 will not auto focus.
Try cleaning the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Aug 27, 2009 | Nikon D50 Digital Camera
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D50 Flashes Err and clicks
hi..
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
Jul 27, 2009 | Nikon D50 Digital Camera
Auto focus doesn't auto focus
So you having problem with AF problem?
Try this (mind your camera to protect it from dust OR another small parts to get in while you opening):
1. Re-connect the lens and the camera.
2. Make sure the connectors is clean.
3. Connect it together again.
Hope this will help! Any questions? Feel free to PM me =]
Jul 07, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Err 99
Hi Ben ,
camera body.
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
Nikon D50 blinking "Err" message
Make sure the lens is mounted fully (give it a little twist to see if the error clears). Also, check the gold contacts inside the body, where the body touches the gold "points" on the lens, to make sure they are clean. A pencil eraser is a good cleaning device for these contacts. I hope this solves it for you.
May 31, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Focus
What is the focal length of your lens?
In order to work with depth-of-field, two things are essentially contributors to fully focused image without depth, 1) it depends on your lens focal length 18-70mm or 70-200mm, 2) your f-stop. 2.8 (large iris) or 30 (small iris).
Simply put, a smaller iris (>15 fstop) increases the DOF, or makes things in front-of and behind the subject more visible/clear. Larger iris (<15 ftop) reduces the DOF, or makes things in front-of and behind the subject less focused/recognizable.
There's quite a lot that goes in to DOF, so check out the link above for the details.
Nov 13, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Feb 03, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera with 18-55mm Lens Logo
91 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
