2000 Volkswagen Beetle Logo
Anonymous Posted on May 04, 2011
2000 VW Beelte - Car smelt like antifreeze the day we bought it, 2 weeks ago. Had radiator flushed and tempature light came on after 4 or 5 days. Need a second opinion, could this possibly be a leak in the heater core or more severe such as thermostat, water pump and timing belt?
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on May 04, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
2603
Points
48
Check to make sure that the rubber o-ring going into the heater core located under the hood on the passenger side does not need replaced. Also check the water pump, these are both very common problems with volkswagen.
Testimonial: "This was very helpful!"
  • Anonymous May 04, 2011
    Great!! Thanks. We will defiantly look into that. I sure hope that will be the solution.
2answers
1990 Crown Vic over heating
engine thermostat is not mention the parts you changed, replace it.
consider the head cylinder gasket, it causes overheats.
a/c is another system, not a part of the system of first.
2answers
1helpful
I bought a 2000 lincoln ls about a month ago and after we bought it, it started having an over heating problem. Since then, we put new fan, new t-stat, new coils and valves, new radiator cap, new belts,...
I believe you have a head gasket or cylinder head problem (cracked head or blown head gasket).. If it is the gasket, the intake and cylinder head must be removed and a new gasket installed.. If it is the head itself, in addition to what have just said, you will have to have the head repaired or get a reconditoned or new one. This is a major repair.
Recently had the raditor flushed and hot light
thats because it is leaking antifreeze into the cab through the heater core
2002 VW Jetta 1.8 ABS, coolant & engine lights
have the fault codes read first
never ignore any light on the dash as they are there for a reason and not decoration
1helpful
2000 Jetta is Leaking antifreeze and smoking
I think you mean you saw water vapor (some call it steam) not smoke.
You probably have a hose leaking (badly). If it's not a hose, your water pump shaft seal is probably kaput.
2answers
2000 VW Beetle over-heats
What do you mean "check the radiator"? Does the radiator not work or only work every other day? You could have a clog in the cooling system and it might be smart to get it flushed out.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
