Question about Lexmark C752dn Laser Printer
Lexmarx x644e Hi, I have a Lexmark x644e (on a network) with the following trays & supplemental devices: Letter tray Legal tray Envelope feeder Duplexer The problem is that the printer forces the users to go to the printer and manually press a screen button in order to print an envelope, and then it makes a load thumping or knocking noise as it is printing the envelope. We have only recently added the Envelope feeder, the Legal tray and the Duplexer. This problem did not present itself in the beginning but only started about two (2) weeks after the additon of these devices. Any direction you can give toward solving this problem would be greatly apprciated. Thanks! John
Printerguy
  • 31 Answers
SOURCE: attach envelope printer & tips for using
On the 4039 model the manual paper feeder fits on the back of the printer. There are two arms that fit into the back of the printer and it just sort of rests there. It takes a little bit of trying to get it right if you've never done it before, but a little patience and you'll get it. If you have a newer lexmark than a 4039 the feeder attaches to the front on top of the lower door. Hope that helps.
Posted on Aug 24, 2007
SparkGap
  • 363 Answers
SOURCE: printer leaves look of burn marks as granular shadow over page
If the paper really is being burnt then there is a fault with the fuser roller temperature control. This would also make a smell. If this gray sheen is made of toner then this may be the laser unit not putting out enough power. The optics could be dirty. One thing to try before attempting repair- Reduce the print density to minimum in the printer advanced settings. This increases the Laser power. Good luck
Posted on Sep 22, 2007
SOURCE: Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Posted on Sep 22, 2008
mdsaeed67
  • 849 Answers
SOURCE: want to print from letter
select the proper tray from the properties of printer. the properties could get by right clicking on printer icon.
Posted on Nov 26, 2008
  • 4 Answers
SOURCE: printing on a #10 envelope
Go into your Word Document and print from "Tools" then "Letters and Mailings" and click on Envelopes and Labels. Sometime the perimeter isn't defined and it is on there but it's outside the scope of your envelope, especially if the return address isn't in the correct place also. You may even be able to correct it where you are by decreasing the "window" of your typing space, it's just too large.
Posted on Jan 17, 2009
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
I have a large list of envelopes that I have to print, I have tried to put the envelopes in the tray but it won't print unless I put them in the manual feeder. How do I fix this problem?
If your printer is the Lexmark E260dn, the tray doesn't support envelopes. The tray is for letter /legal /A4 or A5 paper sizes. For smaller type of media, it has to be fed through the manual feeder. I'm really sorry but I hope I can assist you more on this.
May 13, 2010 | Lexmark E260dn Laser Printer
My printer keeps asking me to Load Mp Feeder letter even after i checked if the papers were lined up properly in tray one. what do i do now?
Hi. Here are some tips to remedy the problem. First, check if the printer is able to detect the exact paper size placed in the trays. Second, check the autosize pins on the left side of the tray and make sure they are not broken. If not broken and the printer is not recognizing the exact paper size (ex. universal instead of letter or legal), try to re-adjust the paper guide, if currently on letter, set it to legal if the printer recognizes the change. Powercycle the device after the change. If still not resolved, printer needs to be serviced recommending the autosize card, cable (if there is any) and the system board. Hope this helps.
Mar 17, 2010 | Lexmark T644 Laser Printer
Can't figure out how to print on statement sized paper.
After I had been attempting to adjust the paper guides in the feeder tray to accommodate statement-size paper, I finally "discovered" the drop-down door to the manual feed tray.  Duh!  This is a networked printer that I've only ever used for printing letter and legal sized documents until now.
May 28, 2009 | Lexmark T640 Laser Printer
I have a T620 that won't print from the trays because it continues to show ''Load MP tray'' on the display. When I drop down the tray and load the multi-purpose feeder, it will print what's in the queue....
Turns out that the paper tray was damaged - the tray was unable to determine the correct paper size, despite fooling with the green paper stop. I had to compare it with a known-good tray to see the problem.
Apr 28, 2009 | Lexmark Optra T620 Laser Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Dell 3100cn Printer
Please follow these steps:
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3100cn-series specifications.
Multipurpose feeder
Standard 250-sheet tray
Optional 250-sheet tray
Optional 500-sheet tray
Optional duplex
unit
S
L
S
L
A4
Y
Y
Y
Y
Y
Y
Y
A5
Y
Y
Y
Y
Y
N
N
B5
Y
Y
Y
Y
Y
N
Y
Letter
Y
Y
Y
Y
Y
Y
Y
Legal
(8.5 x 13 in.)
Y
N
Y
N
Y
N
Y
Legal
(8.5 x 14 in.)
Y
N
Y
N
Y
N
Y
Executive
Y
Y
Y
Y
Y
N
Y
COM-10 envelope
Y
N
N
N
N
N
N
Monarch
Y
N
N
N
N
N
N
C5
Y
N
N
N
N
N
N
DL
Y
N
N
N
N
N
N
User-specified print media
Y
N
N
N
N
N
N
Nov 12, 2008 | Office Equipment & Supplies
Printer Trays
Jul 02, 2008 | Lexmark T632 Laser Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
Lexmark C752dn Laser Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
