SOURCE: hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
SOURCE: E5 error - need to know where drain hoses are
tried to take off the drain hose, but could not get it off the back, only by the disposal. I turned if off and on about 6 times and ran the delime cycle with lots of limeaway. It got the E5 error on the delime cycle, but it worked the next time I tried to run it.
The manual does say to turn it off and on as it drains out the water. Takes a while as it has to heat up the water each time.
SOURCE: what is p3 code on hobart am15 dishwasher
Our AM15 Hobart dishwasher is showing the wrench symbol. Past answers suggested repalcing the thermistor. I did that. Then I did a hard reset on the dishwasher, but the wrench symbol is still there. The water is only getting to 160 not 180. Now what?
SOURCE: I am installing a new
It's likely that the drain pump diverter valve is not closing
completely, as you've guessed. If you remove the front panel, you should
be able to access the pump assembly. First, try to move the diverter
valve manually to see if it's stuck. Second, try to move it from one
side of the chamber to the other without obstructions. If you can't,
you'll need to remove the pump assembly to check it for foreign
materials.the drain valve serves the purpose of diverting the pump water /
pressure to either the drain hose or wash arms, depending on what
position it is in
Check that the valve is opening.
