Microwave Ovens Logo
Posted on May 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven does not work but rang does - Kenmore Microwave Ovens
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on May 08, 2011
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10835218
Points
101584
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Ge oven membrane panel
Order GE range/stove/oven parts today. We ship GE range/stove/oven parts on time or your order is free. Return any GE range/stove/oven part for any reason for one full year. Customer service for GE range/stove/oven parts is available 7 days a week. More than one million parts available. We stock the GE range/stove/oven parts you need for immediate shipment. We have more than 200,000 high-resolution part photos.
My maytag over the range microwave will only work in seconds and doesnt heat probably because its timing in seconds
Hi, Keypad is going bad, but there may be other problems also...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Changing the interior lightbulb of Maytag #MMV5207BCW over the range microwave? How the #$!% do you get the cover off to change the bulb?
I have a belling combi microwave, the covection oven works well but the microwave oven has stopped heating the food up and also the defrost isn't working ? Any tips or does it need repairing and wat are the costs?
I dont have a vent for above range microwave oven
It doesn't have to vent outside. These are designed to recirculate the filtered air back into the room. If you cook without a range hood now it will work fine for you.
Eric
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
11 yr old range/oven ; oven stopped working (clock is out and everything) : stove top is fine. Major expense ro fix ? Am I better off getting new one ?
your clock controls the oven functions. replace clock. probally a little cheaper than a new range but depends on service call fees and labor
My Whirlpool over the range microwave works but
heatman101
xz
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
