Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Green dots I have the same problem as other posters. I have green dots dancing throughout my picture til the tv warms up. Many then disappear but still some remain all of the time. I had a tech come to my house and I gave him the info from this site. He reset the voltage on the board as suggested and now it is worse. This tv is only 3 yrs old. It appears that many people are having the same problem. Any ideas?
  • twmckinn Aug 13, 2008
    I have received a solution that I do not beleive will help. I have green dots dancing through my picture when the images move. After the unit has been on for a while it is somewhat less however still noticable. The tech that came to my house reset the voltage on the circuit boards and now it is no better if not worse. Any suggestions?
    I did have the voltages checked and the tv has been moved.
    Genius:
  • 1,689 Answers
From Shuttle83 - There are many factors that can cause this to occur, First check your A/V cables, then check to see if moving the TV to another location in the room helps. Then the final thing is to have the TV checked to see if your screen bias voltages need to be readjusted (this happens sometimes), this the VScan value / voltage can be adjusted.
if the tv is still under warranty please use the service because getting it repaired if the work around did not work may cost you.
Posted on Aug 13, 2008
  • marlon john madrid
    marlon john madrid Aug 13, 2008
    if that is the case the please check the warranty status of your unit because this will most defenitely need repair. my apologies to what have happened to the appliance
    Genius:
  • 1,665 Answers
A cold solder or bad electrolytic capacitor may cause some isue like this. but better leave as is for now.
Posted on Aug 12, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Aug 12, 2008
    Take care of:
    Keep the ventilation openings clear.
    Do not put TV near appliances that create magnetic fields.
    If your TV is suddenly moved from a cold to a warm place, unplug the power cord for at least two hours, so moisture that may have formed inside the unit can dry completely.
Replaced bulb for a PT-50LC14...worked great til I turned TV on then click off 25 seconds after. 3 hrs later...turned it on and nothing except 8 green blinks on power button then solid red(shuts off) No...
Remove lamp to see if it was not inserted correctly (easy mistake to make) and also make sure door on lamp was closed securely--a safety lever there will prevent set from working if door not engaging the lever.
Jun 17, 2012 | Televison & Video
I have poor color and when the screen is dark many red green yellow dots dancing all over on my LG 42 PX5D
This is a common fault on all LG sets with few people offering any solutions. I can offer a solution that could remove 95% if not 100% of the dots.
Remove the back of the set, there are about 40 screws. On the left hand side on a circuit board you will see 3 or 4 blue plastic boxes with yellow screw adjusters in them. The only 2 you are interested in are VR3 "setup" and VR2 "setdn". Mark the location with a marker pen so that you know where the factory settings were. Then turn VR3 fully clockwise. If this does not get rid completely do the same with VR2. This worked for me today, I was about to throw the TV away but I now have a 95% improved screen, sharper and more vibrant picture and saved hundreds. Hope it works.
Dec 23, 2010 | LG 42PX5D 42 in. Plasma HDTV
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Tv black with red green yellow dots but when warms up it alright
Try backstepping the set resolution on your TV to see if that cures it.
Please rate my help++++Thanks for using FIXYA
Mar 06, 2010 | Gateway GTW-P42M303 42 in. Plasma...
I have green dots all through the picture
green dots throughout the picture means the LCD is bad so unless your Vizio TV is under warranty then you would have to get a new TV cause the cost of the screen would be more then you paid for the TV.
Aug 08, 2009 | Vizio Televison & Video
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Picture quality
I had the same problem before. I had my wireless router really close to the tv. I relocated the router, and the problem never came back.
Jun 05, 2008 | Westinghouse LTV-32w3 HD Television
HL-P5063W Green lines when the tv warms up
My Samsung DLP is having the same problem.  Not sure what to do, but I will contact my warranty place for the second time.  Hopefully they'll fix it.  Any other suggestions?
Mar 23, 2008 | Samsung DLP HL-P5663W 56" TV
LCD TV Picture
I've seen some of these where some of the cable connectors inside of the set need to be reseated . They have become loose . Or you may have a problem in the video circuit of the set . Good luck
Feb 22, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
88 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
