R52WH74 I guess I found the right one, I popped the cap off and tested it with my meter and it tested bad. Now all I need to do is find one!
  • 8,617 Answers
You can get one at the following link, they usually have a minimum order of 10.00 as they ship free, but you maybe able to get them to sell you one if you asked what the shipping charge would be. They have them under the RCA parts. You can leave them a email and they respond quickly. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 11, 2008
02 Cavalier I have no headlights have parking lights brake lights turn signals I also have daytime running lights anybody have an idea
Could be the light switch is bad , but that would be just guessing ? And you don't want to replace parts form a guess posted on here !
The way to find the problem is with electrical testing , using a volt meter , wiring diagrams an leaning how to do automotive electrical testing , how to read an use wiring diagrams etc.. Testing B+ voltage to the headlamps an the ground circuit using voltage drop testing . That is if you want it fixed right .
Electric Testing Techniques You Need to Know
Elec Lesson 6 AC Diag 1
How to read an electrical diagram Lesson 1
Find a wiring diagram at http://www.bbbind.com/free_tsb.html free wiring diagrams . Enter vehicle info. year , make , model , engine size . under system click on lighting then under subsystem click headlamps . Buy a volt meter an test the circuits .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Apr 04, 2017 | 2002 Chevrolet Cavalier Coupe
Why won't the passenger side window roll up?
its electric windows right.
1: blown fuse.
2: controls bad. to motor
3: bad motor
4: jammed window guide, overloading motor
do you want to guess, or test.
if test, then any voltmeter sold finds this easy, even a 10 buck meter at walfart.
Jul 25, 2014 | 2002 Isuzu Axiom
1998 accord wont start after turning it off and starting it almost immediately
yes, and did you tune it up and do all 60 and 100k service points.
spark parts, and filters ? all ?
yes:
then its losing spark, check spark quality time number of cylinders.
the PCM will cut fuel if it (thinks?) that spark is bad, this feature (safety) is a spark read back path that tells the ECM/PCM that
spark is good.
so once spark is good, all 4 cylinder. (max) simple tests, (ask)
then its bad fueling, (more simple tests)
do you want us to guess, or explain the simple tests.
some like guessing.
top good guesses are:
1: bad fuel.
2: bad spark (never ever tuned up, this decade)
3: fuel filter packed, fuel pressure very low. or nil. or marginal.
4: wrong gas cap? causes low fuel pressure?
i check spark, then fuel.
to check fuel i fist check pressure, every time.
the squirt test only proves the pump has electr. power, nothing else. I use a real guage to do that., do you have tools and gauges and a volt meter? if not, its all just guessing.
Nov 16, 2013 | 1998 Honda Accord
Lopes at idle and pops back threw the exaust
It sounds like you have a fouled spark plug and possibly bad spark plug caps. Try replacing the spark plugs and the spark plug caps. The spark plug caps simply unscrew off of the ends of the wires. You can test them with a voltage meter. They should read 5000 OHM's no higher or lower. Buy NGK brand replacement caps. They are what come standard on your machine and will cost about $5 each instead of $20 each from Kawasaki. Hope this helps.
Sep 05, 2011 | 1996 kawasaki VN 1500 Vulcan Classic
I own a XG-91D monitor that the screen goes black after about 5 seconds. I found 2-470uF 25V capacitors on the power supply board that were leaky - replaced them but the problem still persists. There...
Replace thee 1000uf caps too. A capacitor meter will not test the ESR ( equivalent series resistance ) of the caps the cap meter will show them to be good but an ESR meter will show then to be bad. Also be sure to use low ESR caps. If you use general purpose aps like from Radio Shack it can damage the board board because of the ESR rating. The temp rating needs to be 105c or the new caps will blow out within a month because of the heat in the monitor case ( No fans ).
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 17, 2010 | Xerox XG-91D 19" LCD Monitor
RCA R52WH74 turns off 3 times
Hello Kira-chan,
You are going to have to take those capacitors out of the Tv and check them on a capacitance tester. Some digital multi-meters have them, but I would suggest using the LC102 by Sencore That way you can check the ESR, and the dielectric absorption of the capacitor. It is my suspicion that these caps are bad, but should be checked before replacing them.
In addition check the BLUE and RED CRTs for cracks around the neck oy the tube, BE CAREFUL.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a Porter Cable BSV750 generator with no electrical output. How do I test the capacitor?
You need an multi meter, on the ohms scale. Short the two prongs on the cap out, removing any voltage on it. Put your meter to a mid range ohms scale. Touch the leads to the prongs on cap and watch your meter. It should start climbing in value and then go to 'OL' if it's digital. If it's an analog meter(with a needle) it will go all the way over to 'infinite. This means it's good.
If it's bad, it will just read 'OL' or go right to 'zero' meaning it's either shorted or open.
Jun 23, 2009 | Porter Cable Portable Generator BSV750
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
Open Questions:
Magnavox MWR-20V6 DVD/VCR recorder fails to record one time but not the next This problem just recently started as the unit was functioning perfectly up to now. And I've kept the unit in excellent condition and free of any dust. What's happening is this. When the timer is set to record a program, the unit will turn on and begin to record. But after about 9-10 seconds of recording, it will fail and you'll see an error message saying you cannot record on this disk. FYI, this happens too when not using the timer and just pressing record. And in both cases, it's been hit or miss, so one time it successfully records no problem and the next time no. So you don't know when and if it's going to happen, which is really frustrating! What's even weirder is that once it failed, you can wait a few seconds and try recording again with possible success. So if it failed at first, it may work the next time, but who knows if it'll work after this. And even if it does work the next time, after that, it's again hit or miss. This recording problem happens even when dubbing. So it doesn't matter if you're copying from VHS to DVD, using the time, or just hitting DVD record, the same recording error happens. And as I said above, it may work the next time but who knows? And even if it worked then, anytime after that is also very hit or miss. Nobody else touches the unit and it's never been moved or banged. So again, I've kept it in very good shape and working order. No problems whatsoever on the VCR side. And I most often use DVD-R discs rather than RWs, but even with RWs, the same problem can happen. Lastly, finalizing has also become more hit or miss now when it used to be very consistent. So I don't even know when or if it'll be successful in finalizing a discs. Most times, it does work, but a couple of times, it hasn't. Lastly, a weird thing with discs that failed to finalize is this. A few of them were finally able to be successfully finalized after just sitting around for about a month of not being able to be finalized. So for whatever reason, a few of those discs that wouldn't repeatedly finalize suddenly worked. The rest of those that were not successful still cannot be finalized. And I've kept all these discs in plastic sleeves or in a disc case.
Jan 17, 2018 | Magnavox Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
