Do you want your calculator to use more than 2 decimal places? Or are you asking how to actually put a decimal place in your numbers.Do you want your calculator to use more than 2 decimal places? Or are you asking how to actually put a decimal place in your numbers.
You can't post conmments that contain an email address.
CUT: Values are cut off to the number of decimal places speicified by the current Decimal Place Selector setting
UP: Values are rounded up to the number of decimal places speicified by the current Decimal Place Selector setting
5/4: Values are rounded off (0,1,2,3,4 are cut off; 5,6,7,8,9 are
rounded up) to the number of decimal places speicified by the current
Decimal Point and Separator Symbols You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator. • To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below. Display the selection screen. (Disp) 1. Press the number key ( 1 or 2) that corresponds to the setting you want to use. 1(Dot): Period decimal point, comma separator 2(Comma): Comma decimal point, period separator
Press 2nd [FORMAT]. Press 0-8 for the number of digits after the decimal point, or 9 for floating-decimal, followed by ENTER. Press 2nd [QUIT] to exit.
Have you tried messing around with the decimal setting and setting if to F (floating) or somethings besides 2? This should affect your inputting of numbers however. You're not hitting the percent key (%) by any chance, are you. I don't have this calculator but I'm not aware of any function that inserts a decimal point in a number that you enter (other than the percent key). The decimal setting should only affect the number of decimal points in the answer. Good luck and let us know how you make out. I'm curious.
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][5][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Set the +43210F switch to + (or 2).
On some models it is A43210F, then use A (or 2).
+ mode will let you enter numbers (monetary) without the decimal point and assumes cents; 2 mode will just round to 2 decimals, but you must enter the decimal.
