Question about Hitachi 43FDX01B TV
Hitachi 43FDX01B Convergence Problem
I have 43" HD rear projection 2001 Hitachi TV that has a major convergence problem. Colors are not lining up, Bow at top and bottom, cannot adjust the horizontal convergence using the remote. I called a Technician who came out and replaced both IC's and a burned out resistor. Still had the same problem. No change. He replaced the same IC's again thinking he may have had a bad part, no change. He is at a loss as to the next step. I would like to get this fixed, but hate to call someone else since he has time and parts invested. Does anyone have any idea what else could be wrong? He states that he has heard of at least 8 other tv's of this same vintage with the same problem and no one seems to have a solution. 43" hd rear projection changed convergence ic"s and open 2.2 ohm resistor red bows at top and bottom
  • 2,337 Answers
It looks like the voltages might not be getting to the STK ICs. I would suggest for the tech to check all the pico fuses that are related to the convergence circuitry. He needs to check and make sure that +28 volts and -28 volts are getting to the ICs. If those voltages are missing, there could be a blown pico fuse.
Posted on Aug 11, 2008
    Sergeant:
    Champion:
  • 248 Answers
Here are the directions for getting into the ’secret’ convergence menus. You will need your remote operational to do this:
  1. Turn on the set
  2. Press and hold the convergence button the set and hit the input button on the remote.
  3. Convergence adjust is now engaged.
You should see a grid on the screen. This means you are now in the convergence adjust mode. Basically, now it’s up to you to adjust as you see fit. To move around on the grid,
use the following keys on your remote:
  • 2: up
  • 4: left
  • 5: down
  • 6: right
Use the cursor on your remote to move the points around. You also have the ability to select a mode for adjustment. The various modes allow coarser or finer tuning of the convergence grid. Generally speaking, you should start out in the 3 X 3 mode (meaning you have access to adjust 3 points on the grid) and then move to finer adjustment modes to perfect the picture. Change modes by doing the following:
  • Press Recall 5 times to activate 3X3 mode
  • Press 0 5 times to activate 7X5 mode
  • Press input 5 times to active 13X9 mode
Generally speaking, the first step is to get just the green color aligned. Press MENU on your remote and then EXIT and you should see only the green lines. After you adjust the green, you will want to pop up another color over the green and align it with the green lines. Here are the modes:
  • Blue: INPUT button on the remote
  • Red: 0 button on the remote
  • Green: RECALL button on the remote
  • MENU: to remove an activated color and return to just green
Again, to start with just green. Then activate one of the other colors (red or blue.) Now, move around and adjust so the lines all line up across the screen vertically and horizontally. If you want this precise, you will have to develop some kind of overlay, but for fine tuning, you should be able to eye it.
When all the colors are properly aligned, you will see white lines. Don’t worry if it isn’t absolutely perfect - a small amount of fringe is acceptable and will go unnoticed. When you are done you will want to save the adjustments you made. To do this:
  1. Press PIP MODE on the remote twice (the first time it will as you if you want to save, hitting PIP MODE the second time does the saving
  2. The screen will blank briefly. Then you will see a pattern of evenly spaced green dots. You have successfully saved the settings once you see this.
  3. Hit PIP CH to go back to do more tweaking.
At this point, the changes are saved. Turn off the TV and back on again to see the results with a normal signal. /* 0 ) { location.href = "http://zeroization.com/?cat="+dropdown.options[dropdown.selectedIndex].value; } } dropdown.onchange = onCatChange; /* ]]> */
  • Anonymous Aug 11, 2008
    1. Turn on the set
    • 2: up
    • 4: left
    • 5: down
    • 6: right
    are the modes:
    Again,
    be able to eye it.
      you see this.
    Master:
  • 623 Answers
Try this site
www.hitachi.us
SOURCE:
There is a bow in the picture top and bottom of screen
The tv have a problems known as a convergence problems,it is dead.Tv have colors R,G,B lines mis alignments,have shadows pictures or 3D picture look alike?Yes the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replace on the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 09, 2011 | Apex Digital GB4308 43" Rear Projection...
Picture is going into a three d color
Ur tv have a problems known a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?The tv convergence board is dead.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 43FDX15B 43" Rear Projection...
There is a gost and crazy color
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D colors look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must have be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Hitachi 43FDX15B 43" Rear Projection...
I have 2 images on the screen
Tv have a problems known as a convergence problems,it dead.Very common problems and design flaw of all DLP tvs.The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence boaard,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 17, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Red color is out of alignment
The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must require chaging to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Ihave a toshiba 43 inch hd 2002 rear projection the picture has shiffited to the right can I fix this
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows picture or 3D picture? The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,require changing to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 16, 2010 | Toshiba 51H84 51" Rear Projection...
I have a Hitachi Ultra Scan HD TV model #43FDX01B - Green line
Hitachi Projection TV Repair Kit for one or more of the following symptoms
This might not be your model but you should contact them to see if the have the parts I know they list the manual
Feb 18, 2018 | Hitachi 43FDX01B TV
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 43FDX01B rear projection TV
It is adjustable only in the technician menu. You will most likely need to replace the convergence IC's in the TV. This is a very common issue. The locations are IK04 & IK05 and are generic part numbers STK392-110's.
Mar 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43FDX01B TV Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
