Question about Avery Office Equipment & Supplies
I am using Avery T-shirt transfer paper. The man in the white uniform keeps printing green instead of white. I am putting this photot on a white t-shirt, printed from my HP Photo Smart D7360. After applying diffenent tecniques and printing 6 times, his uniform is still greenish. thank you for your help. Barbara
  • canoe2 Aug 13, 2008
    This was the first time I used your program. Came across FixYa while looking for a solution.
    Awesome Probelm Solver! This worked the first time!!! Thank you so much! Barb
  • 446 Answers
GREEN is a combination of Cyan and Yellow, although i would assume that all other colors are working fine if you can find a printing properties, and reduce the amount of cyan it would help you a bit until you have achieved your desired result.
otherwise you may have to recalibrate your printer to suit a perfect color matching
Posted on Aug 11, 2008
  • ariel santos
    ariel santos Aug 14, 2008
    im glad you make it work... cheers
Can i transfer my designs on a t-shirt with the print shop 2?
Any image can be added to a T shirt. You can buy specific paper which you print reverse on and then iron or take the image to a local T shirt shop. I used to run one and we would charge around 15 pounds including the clothing. Full colour upto A3 is the norm
Jun 06, 2012 | Software MacKiev Print Shop 2.0
My HP Deskjt F4280 will not print Avery injet 08371 business cards. I tryed the other number on the cards, 5371. Neither of them will line up proper. If I print on a blank paper it is printed correct. ...
you realy cannot print with that paper the ink cannot penetrate through, i have an experience here before and tried it on epson it print perfectly
Aug 07, 2011 | Office Equipment & Supplies
Is Canon PIXMA IP1800 can handle T-Shirt Transfer Paper? if it can, what kind of transfer paper that will be good for IP1800?
There are several brands of T-Shirt transfer paper out there, and all are designed to work with InkJet printers just like yours. Personally I've used the Avery brand sheets, and they are widely available at local stores like WalMart, Staples, OfficeMax, etc.
I've also provided a link to the sheets available for online purchase from Amazon.com -
http://www.amazon.com/Avery-Personal-Creations-T-Shirt-Transfer/dp/B004E2S3MC
May 05, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Printing t shirt transfers
I believe that printer does not support this option since it is using toner and toner printer has different technology where it creates electromagnetic reaction to paper itself and toner when printing . What you need is an inkjet printer. You can check Epson products and consumables and Kodak too.
Hope this helps
Apr 28, 2010 | Konica Minolta magicolor 2300DL Laser...
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Can the Canon MX310 print on transparencies?
Manual does not mention Transparencies.
Manual states that It will print T-shirt transfers:
T-Shirt Transfers TR-301
This paper is used to create iron-on transfers. The image is printed inverted.
Paper Support Load Limit: 1 sheet
Paper Output Tray Load Limit:
We recommend that you remove the previously printed sheet from the Paper Output Tray before continuously printing to avoid blurs and discoloration.
Paper Thickness Lever: Right
Media Type:
Printer Driver Setting: T-Shirt Transfers
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing dark tshirt transfers - can't override the flipped image
Hello I think I can help you. I Would not use T shirt transfer when you make up your print I would select poster print or any other form that does not automatically reverse the image. The reason your software is designed to do this is on the regular transfer paper your laying the image down on the shirt, so for it to come out right it has to be reversed. With the dark T shirt transfer paper your peeling off the backing and putting the image face up on the T Shirt.
Dec 23, 2008 | Canon i80 InkJet Printer
Iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture. CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
Jul 23, 2008 | Lexmark X1290 All-In-One InkJet Printer
113 people viewed this question
Top Avery Office Equipment & Supplies Experts
Lawrence Oravetz
Are you an Avery Office Equipment and Supply Expert? Answer questions, earn points and help others
