Question about Bosch Washing Machines
Have a bosch WIS28440GB drain was blocked. I have cleared the drain but the washer will not re-start. Is there some kind of reset sequence to reset the machine. Rob
SOURCE: Bosch washer - taking apart the anti-siphon valve
I have a Bosch Nexxt Washer when it goes into the spin cycle I get EOO2 and the washer stops
Posted on Apr 14, 2009
localwonder
  • 6784 Answers
SOURCE: Water is has not drained
Check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 19, 2009
  • 118 Answers
SOURCE: filter was blocked so now washer needs resetting
Have u unpluged it for 3 mins and plugged back in to see if that works hope this helps
Posted on Sep 13, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Posted on Nov 11, 2009
Testimonial: "Thank you so much. There were some wood splinters and a nail stuck in there! No wonder it wasn't working!"
  • 20 Answers
SOURCE: I have a bosch washer
Most of the time you can reset the board by unplugging the unit and let it rest for minutes and the plug back in, if not you may need tech that specializes in Bosch so they can call the Bosch Tech line for the sequence, the reason I say this is because the engineering codes can be deleted and then you will need to purchase a new board.
Posted on Mar 10, 2011
Bosch dishwasher she43m06uc/48 constantly trying to drain. Cannot reset to end cycle.
Have you tried shutting off power to it from circuit breaker panel for about a minute and leave door open to dish washer . If that does not fix it the float Is stuck from grime build up . You can down load a maintenance manual online on how to access it and cleaning tips.
May 17, 2014 | Dishwashers
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jul 02, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have just bought and installed a new Bosch WIS28440GB washing machine. Works fine until it starts to drain when it starts to pump water but then trips the electrics. The drain is connected to an...
Bosch WIS28440GB washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Sep 17, 2011 | Hotpoint Aquarius WD63 Front Load...
The pump is not pumping water when in drain cycle and "Pump Blocked?" error is displayed. The washer has been drained and the pump cleared of debris (penny, toothpick and two small rectangular...
Hello & Welcome to FixYa
If you have cleaned it completely and nothing is blocking the drain pump assembly then it means that the drain pump is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jul 25, 2011 | Bosch Axxis WFL 2060 Front Load Washer
I have a bosch washer machine WIS28440GB, Recently changed the drum gasket due t damage and had some issues with the lock. This has now been fixed but now when the washer is put on a cycle it misses the...
Mar 10, 2011 | Bosch Washing Machines
My washer has E:13 on the display. I called Bosch
According to the service manual, you should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. I would run the short wash or refresh cycle without detergent and hopefully your lines will clear. I have also read that if this persists, powder HE detergent is better to use instead of the liquid because of certain chemicals contained in the liquids that cause it to congeal in some front loader drainage pipes. I hope this helps.
Jul 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Mar 20, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Message: drainage blocked
scgawlik,
Happy to assist you,
You said,
The pipe in the back is not clogged, it is wide open. When we removed the cover for the pump in the front and open the valve, the water obviously drains out. However, when you put it back together and try to run it, it will go through a cycle and when it gets near the end of the cycle that when the message appears drainage blocked and won't drain.
The electronic type washers , can be unplugged and after 5 minutes restarted and the system is then rebooted. This resets the system and clears the codes !
If the drain is not blocked then you have a faulty sensor or a bad pump
Sep 14, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
63 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
