Question about Samsung Televison & Video
Samsung 32" LCD TV. Want to reset it to factory to get "Plug and Play" menu active.
2008 version has factory reset built in. Hold "exit" on the remote for 10 seconds and a screen will appear that allows you to select "return to factory default"
Posted on Aug 16, 2008
HD worked with HDMI cables on HD Cable Box & ROKU3. Now only get SD transmission. Is it worth repairing?
On a 32' tv the repair probably wouldn't be worth it after labor costs. They're cheaper to replace with a new one and less of a hassle.
Mar 01, 2014 | Samsung LN32B360 32 in. LCD HDTV
Accidently entered into store mode, but cant enter "plug and play"
hi, let try this.
Open menu , choose setup - push enter.
Choose plug and play, enter language , pass code, than follow instruction until setup home use and demo store appear.
Choose home use.
Its work with my TV.
Mar 18, 2011 | Samsung LN32A330 32 in. LCD TV
How do I reset my tv to factory settings. samsung 32 inch LA32R81WDx/xSA
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
Aug 05, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I have a samsung TV that freezes temporarily.
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK
Nov 11, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
I have a samsung tv and dvd player and it has just started coming up on screen when i load a dvd to play a region error messagesayinh no good.It has been working ok before this.i just recently upgraded my...
make sure your tv is set in right language and location because after the big re-tune you might of entered wrong ones
the best way to do this is reset back to plug & play put tv in analog mode press TV/DTV on remote and then MENU ( NOT DTV MENU ) move down until you see plug & play in one of the menues press enter and follow on screen instructions
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
How do i reset factory sttings on samsung lcd tv
go into analogue tv press menu move down to settings you should be able to enter plug and play in menu press ok( if you can not enter it you are not in analogue )
if not solve problem try this !! warning !!
you will enter the service menu DONT ENTER OR CHANGE ANY OTHER ITEMS THAT ARE DISPLAYED AS TV WILL NOT WORK IF YOU DO
With tv in standby press INFO / MENU / MUTE / STANDBY on remote
then use ONLY DOWN nav-key move to number 12 FACTORY RESET
press RIGHT nav-key will reset all tv settings to factory ones
PRESS STANDBY TO EXIT on remote
you will have to RETUNE after tv after
Oct 25, 2009 | Samsung LN46B530 LCD TV
Channel stuck on TV
This may work;
info
menu
mute
power
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Feb 24, 2008 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Jan 07, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
153 people viewed this question
Jerry Greenberg
Jerry Greenberg
