Question about Sony PlayStation 2 Slimline Console
Ps2 turns itself off.
The power light on my ps2 immediately turns to red when I press the on/off reset button. I also get a black screen on my tv. Please help!
  • 2 more comments
  • Anonymous Nov 16, 2008
    The consol runs just fine, as long as it is open, but the second I close it (with OR without a disc in it), the green light immediately turns red, and the consol turns itself off. If I try turning it on while it's closed, it won't even turn on at all. Help? I'm going crazy.
  • Anonymous Jan 08, 2009
    i have the same
  • Anonymous Mar 15, 2009
    my ps2 turns off by its self when i turn it on
  • Anonymous May 11, 2010
    Does it turn green then immediately to red?
    New Friend:
Hi, I had same problem, I just changed the fuse underneath mainboard, 3.15 Amp 120V If it doesn't work change this for 4AMP fuse
Posted on Oct 23, 2009
Yes my slim ps2 does that any help
Posted on Sep 22, 2008
SOURCE:
While I was watching my Emerson TV I heard a loud click and the screen went black and audio went off. When I press tv button on cable remote the tv button glows red, and nothing happens on the tv.
Hi the power supply might have shut down through overheating turn the power of at the wall socket & wait for a short time before trying again the TV might reset itself if this doesn't work its probably shut down from a faulty component. good luck
Oct 23, 2016 | Emerson Televison & Video
Tip
Try this to play DVD movies on your PS2 if it wont play DVD movies.
If your PS2 works fine with Games and just wont play any DVD movies at all.Then you should try this trick to play movies on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:894e4e5.jpg
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like3aef030.jpg
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the movie plays itself.If your lens is good then it will play DVD in first go else try again till it PLAY your DVD movie.
Thank you!
on Nov 29, 2009 | Sony PlayStation 2 (PS2) Console
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I had my dish installed to one tv. Now i switched out the tv for another one how do i get my dish to work with the new tv
Hi there this is Kimberly Escobar with DISH Network. I will be glad to help you by providing you the information that can help you. To program the DISH Network remote with your T.V we usually integrate a code into the remote that works with the brand of your T.V allowing our remote to function with the T.V itself by reading your post you don't mention the brand of your television but that is not a problem there is another way to help program your remote without having to use a code, it is called Power Scan in the Power scan procedure we search for the code that gets the remote to control your T.V. To perform a Power Scan your T.V must be on, you press and hold the T.V button until all the other buttons at the top light up in red. Once they light up in red you enter the number 500, you wait for the top buttons to go off and the you will press and hold once again the T.V button until the buttons light up again once you see them come on you will press the big red Power button on the remote once immediately after you press the big red power button you will press one repeatedly the channel up arrow one time after another until T.V turns off immediately after it goes off press the pound button (#) you should see the T.V button light up 3 times then try turning the T.V back on using the remote it should work. Here is this link http://www.dishnetwork.com/SupportSection/power-scan-instructions it shows you the procedures. I hope you find this helpful if you have any questions or need further assistance please contact us directly at 1800-333-DISH thank you.
Jun 25, 2010 | DISH Network IR Remote Control
On switch button turns green and immediatley turns off again. My disc in the beggining stoped spinning eventhough i can here it trying to spin
Can you hear the fan spinning on the inside of the PS2? If the PS2 comes on, loads the disc, then shuts itself off, chances are it is overheating and shuts off to prevent damage. There is a small fan on the inside of the Slim PS2 that keeps it cool.
If you press the reset switch and it goes from red to green and immediately back to red without ever turning on, your motherboard is shot. ESD damage.
Nov 11, 2009 | Sony PlayStation 2 Slimline Console
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Tv won't turn on or respond
if its a sony bravio LCD the backlight inverter failed
Dec 06, 2008 | Televison & Video
Plasma tv screen goes black once you turn it on. Only sound
I have a panasonic TH-42PX60U plasma TV. When I watch TV programing I have no problems, or with the DVD input. But if I switch to another input, be it video game (PS2) or vcr the screen sometimes goes black and the red power lcd light next to the power switch flashes. Holding the power button in for a few seconds will shut down the tv. Then I can turn it back on and it may operate normally again for a undetermined period of time, before the screen goes black again. This never happened when new. The tv is about 1 year old. Any ideas on this problem? Thanks Ernie
Aug 13, 2008 | Televison & Video
PS2 No Green Light
Maybe it has something to do with your power supply, try replacing it with a different one.
Jun 09, 2008 | Sony PlayStation 2 (PS2) Console
Ps2
you say it wont turn back on but it has power.
is the light red ( stand by )
or do you have green and blue lights
Did it fall????
try cleaning the disk and the lens
you can also run the auto diagnosis..
HERE'S HOW
Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point. NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
the above is a copyright of the PS2 user guide
Dec 29, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
2,383 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
