Question about Watches
Need correct instructions to set Disney mc2274 watch. The paper that came with it is wrong and I can't turn off the chime
  • 1 more comment
  • Jay Lambert Dec 14, 2008
    No longer have the watch, but really appreciate the help.
  • Anonymous Jan 02, 2009
    I have the same problem with an Athletic Works stopwatch (from walmart). The solution offered worked on mine too
  • Anonymous Jan 23, 2009
    This solution works for me to turn off the hourly chime, but not the daily alarm. I can't figure out how to turn it off, so it goes off once each day and drives me nuts. Any suggestions Ralph? Thanks in advance.
Hello, To turn off the hourly chime hold down the RESET button and then press the MODE button. All the day marks will appear ON when the chime is enabled. Hope this helps. Cheers, Ralph
Posted on Dec 11, 2008
  • 2 more comments
  • Ralph94583 May 18, 2009
    Hello all, I'm sending the instructions in multiple parts. For items 1 through 4:
    Instructions for Operating
    Disney Midsize Mickey Mouse Digital Sport Watch #MC2274D
    1. Normal Time Reading:
    a. Normally shows hours, minutes, seconds and weekday
    b. Press START to show month, date and weekday
    c. Press RESET to show alarm time
    i. Press START to toggle daily alarm on and off, and alarm bell displays when on
    ii. Press MODE to toggle hourly chime on and off
    Note: All day marks appear when hourly chime is enabled
    d. Press LIGHT to turn on the back light
    2. Normal Time Setting:
    a. Press MODE three times to set the time, date and day
    Note: Will display (TU) mark flashing
    b. Select the item to change by pressing RESET and advance item by pressing START
    i. The seconds will be flashing and can be set to 00 by pressing START
    ii. First press RESET to go to set the minutes by pressing START
    iii. Second press RESET to go to set the hour by pressing START
    · Setting 12/24 hour format can be selected by 1 day cycle
    AM/PM in 12 hour format, or H in 24 hour format
    iv. Third press RESET to go to set the date by pressing START
    v. Fourth press RESET to go to set the month by pressing START
    vi. Fifth press RESET to go to set the weekday by pressing START
    c. Then press MODE to return to Normal Time Reading
    3. Chronograph: (Can count up to 23 hours, 59 minutes and 59 seconds)
    a. Press MODE once to show chronograph mode
    Note: Will show (SA), (FR) and (SU) marks flashing
    b. For NORMAL mode timing
    i. Press START to start counting with (SA) and (SU) marks flashing
    ii. Press START to stop counting
    The colon will not flash but (SA), (FR) and (SU) marks will be flashing
    iii. Press RESET to reset the time to 00:00:00
    c. For LAP mode timing
    i. Press START to start counting, (SA) and (SU) marks flashing
    ii. Press RESET to hold the current count but continue counting
    The colon and (SA), (TH) and (SU) marks will be flashing
    iii. Press RESET to show the counter counting again
    iv. Press START to stop the counter and hold the count
    v. Press RESET to clear the counter to 00:00:00
    vi. Press MODE to return to Normal Time Reading
    4. Alarm Function
    a. Press START and RESET together to test alarm
    b. Press MODE twice to go to set the alarm time
    Note: (MO) and the hour will be blinking
    c. Press START to set the hour time
    d. Press RESET to go to set the minute time
    e. Press START to set the minute time
    f. Press MODE to return to Normal Time Reading
    g. When alarm sounds press RESET to cancel alarm
    h. When alarm sounds press START to snooze alarm,
    alarm will sound again in 5 minutes
Clock Manuals
leave it running when it gets to 12 oclock it wiil reset itself
May 02, 2013 | Watches
Timex 1440 sports watch. How do you turn off the chime on the hour every hour?
Hi aburns983,
You can easily change the time and turn off the chime of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Nov 05, 2009 | Timex 1440 Nylon watch
Cant get old watch to chime
Instructions are on the inside of the back cover: 1. short circuit AC and the battery clamp. 2. the hands will rotate once clockwise 3. in the chime mode, pull out the crown and set the hands to the 12:00 position 4. Return the crown to normal position, change to time mode and set the desired time
Jul 06, 2009 | Disney Lorus Rare Musical R2306AX Watch
Kenneth Coleman Watch Beeps Every Hour! It Needs to STOP!
think of the top buttons from left to right as A & B and the bottom buttons from left to right as C & D. The way to turn the chime off and on is by holding the C & D Buttons simatainiously and the pressing the B button. This will allow you to turn the Hourly Chime Off and On. When you see the digital chime pattern in the display the chime is on. When no pattern is shown the chime is off. Hope this helps the ton of people who have purchased these watches & either did not have instructions with or lost them. This perticular watch has been annoying the whole household for quite sometime and has now been put to rest..lol
Mar 27, 2009 | Watches
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 | Watches
SET THE TIME
: 1. With the time and date showing, press the top left button. 2.Press the right top button (this sets seconds) 3.Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm). 4.Press the bottom left button, minutes flash. Press the top right button until correct minutes. 5.Press the bottom left button, month flashes. Press the top right button til correct. 6. Press bottom left button, date flashes. Press the top right button til correct. 7. Press bottom left button, day flashes. Press right top button til correct. 8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished). To turn off the chime and alarm, press the top right button repeatedly until the CHIME or CH symbol is gone, then press the left top button. Repeat for alarm but watch for the bell icon or ALARM or ALM to disappear, then press the top left button.
Feb 16, 2008 | Columbia All Sport watch
Diesel Digital Watch DZ7069
I finally figured out how to set the time on this watch! Like others the included manual didn't have instructions for this model.
Hold down all four buttons on the watch, this will do a factory reset.
Hold down the top left button, which brings you into the configuration mode.
Pressing the bottom left button will cycle you through all the settings for the time. For each setting, the top right button increments and the bottom right decrements.
When you are done, press the top left again.
Dec 28, 2007 | Diesel Audio Diesel Watch
Alarm
You can press the four push buttons at same time to reset the watch and then set the time again, it will help you to solve the problem
Thanks
Tsai
Nov 05, 2007 | Freestyle Shark Buzz Wrist Watch
Watches Logo
1,565 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
