Question about Lands Phones
I need to reactivate my uniden cordless phone with remote extra handset. It was on a second phone line in my home, and that phoneline has been cancelled. Now, both units are charged, but and plugged into phone line, but there is no dial tone. I have two other remote phone lines in other rooms that are working, including another answering machine, but they are old, and I want to switch to new uniden phones.
  • LoNews Aug 11, 2008
    The model number for the dual-handset cordless phone is
    DXA14588-2 for the base station. The extra remote came with the phone - the only thing it says it DC IN 9V on the bottom of the charger.
    Since the uniden is new, I want to use it as my main answering machine, but I don't want to disconnect the old Panasonic until this one is live. The headset on the Panasonic was given a bath in the dog's waterbowl by a toddler, so it is dead but answering machine works. I also have another Panasonic without answering machine that is the only working cordless in the house, so I don't want to unplug it either. Please asvise sequence.
    Thanks
  • Dave Grunbaum
    Dave Grunbaum May 11, 2010
    Hello, 2 questions:
    1. Can you provide the model number of the base station?
    2. Is the extra remote the same model as the unit in the base station?
    Resetting and registering the handsets is a little different for each model type.
    Thanks
  • 18 Answers
This should get the job done for you!
To re-register DXA14588-2 handsets:
  1. Pick up the handset from the base. Press and hold [find handset] on the base.
  2. While holding [find handset], place the handset in the base. The charge/in use LED on the base begins to flash, indicating the base is registering the handset. Wait for at least five seconds.
  3. Pick up the handset from the base and press [talk/flash]. If the display shows TALK, the handset is registered. If not, place the handset in the base to try again.
  4. Press [end].
  5. Place the next handset in the base and wait for at least five seconds. No need to hold [find handset] this time.
  6. Repeat steps 3 - with any other handsets you have.
Please let me know if you have any further questions.
Good Luck!
Posted on Aug 12, 2008
Can i add 3rd handset to uniden xs 1455+1 cordless phone
if you can get the exact model as the existing hand set it should not be a problem
just follow the installation process to get the base to recognize it so that it connects
Dec 05, 2015 | Uniden Cordless Phone
Tip
Connecting extra handsets to main base
Call your phone, while it is ringing put your extra handsets on the main base. I did this and they started to ring when on the base and they worked after that. You may not need to call the main line, only put the extra handsets on the main base to get them connected but I didn't try this so I don't know.
on Oct 18, 2008 | Uniden Cordless Phone
I need the remote access code to call and get messages when I am not at home
Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning at http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl to download a copy of the manual.
May 21, 2013 | Uniden DECT 6.0 Cordless Phone with...
How do I remove the silent mode from my uniden cordless phone handset
Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Feb 18, 2013 | Uniden DECT 6.0 Cordless Phone with...
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
Phone won't register
Try this,
remove the battery from each of the handsets that will not register for about 30 seconds. Reinstall, and try to register the handsets.
I had the same problem, and this is how I got it to register.
Reply back if this worked.
Jan 23, 2009 | Uniden Cordless Phone
Conference calls
this will be threw your service provider to set up more than a 3 way calling plan
3 way should be standard service with only 3 people at time anything extra needed the service provider can set up the extra 3 waying +
on the phone handset if your just looking for in home conference calling to others just click the conference button find the handset you want to talk too or all the handsets this is conference calling
Jun 01, 2008 | Uniden Cordless Phone
Uniden phone
If this is a standard home phone, try another handset or handset cord. It it's wireless, it's the handset.
May 07, 2008 | Uniden DCT646-2 Cordless Phone
PLEASE REGISTER!!!!!!!!!!
You may need to "reset" the whole system1.gif. Do this by :
1 Unplug phone line, power to charger base, and remove the batteries.
2 Wait a couple of minutes.
3 Plug in batteries first, then phone line, and finally the power cord.
Then try to set the phones in the basecharger to register.
Dec 27, 2007 | Uniden Cordless Phone
Register extra handsets
place handset in base, press menu, press vol button
select HS registration,
on handset press & hold # for 2seconds
Nov 23, 2007 | Uniden TRU8885-2 Cordless Phone
Lands Phones Logo
468 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
