Question about Brother Office Equipment & Supplies
Plugged into a UK outlet...heard pop...can I fix this?
    Master:
  • 397 Answers
No. If the printer has a seperate power supply you should be OK just buying a new power supply but if the power cable plugs into the printer itself you will need to take it to a service centre.
Posted on Aug 11, 2008
SOURCE:
How do I contact kindle in uk ?
I've heard of these problems before but without knowing your exact model number just try pressing and holding the power button for a FULL 40 seconds. Ensure that it is not plugged into any power outlet or PC first. Hold it for 40 seconds. Time yourself. Better to go longer than not the full 40. Hope that helps. After you've done that, power it back up.
Kindle is made by Amazon so contact Amazon.co.uk
Feb 28, 2015 | Amazon Kindle
Plugged in new oven heard a pop and a burnt plastic smell oven is dead
Call for warranty service it is in the owners manual I had a customer 2 weeks ago plugged in a 120VAC oven into a 120VAC outlet that was wired for 208/240VAC doubt if thats your problem but call for service
Jan 30, 2014 | Maytag 24" Built-In Single Electric Wall...
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
Oct 12, 2017 | Kenmore Refrigerators
I plugged my 120V Sony dvd p[layer into the 220V outlet. I didn't check it out. Anyway, I heard the fuse of the AVR popped and it turned off. I removed from the main outlet. I smelled it and touched it and...
you have just fried your power supply and it will need replacing, that doesnt mean that is all that will need replacing, depends on how well protected the main board is from the power circuit
Apr 03, 2011 | Televison & Video
I plugged in my Dell PC from US with 115V in a 230 outlet in Asia. Heard a pop noise and all went dead. What is the fix for this? Please help.
If you're lucky, you'll only need a new power supply for this machine. It probably hasn't damaged the rest of the PC (from my experience of repairing such things), but you'll need to try a power supply to find out.
Apr 15, 2010 | Dell POWER SUPPLY Power Supply
Plugged my US made PC into a 220v outlet!
Hi
You need to change power supply unit. You can find a guide with screenshots here
May 03, 2009 | E-Machines eMachines Desktop PC
Loud pop with smoke
Don't know why just plugging it into a new outlet would cause that unless you have a problem with that outlet. Sounds like it may have burned out the low voltage circuitry. I would advise having the outlet checked and certified safe before plugging anything else into it. Also, it sounds like the oven is toast, (Sorry!)
You can get parts on-line from AppliancePartsPros.com/Parts
May 23, 2008 | Emerson MW8107WA Microwave Oven
Roper Fridge problem
you tried ither outlets andthe refrig wouldnt work??? or the surronding outlets didnt work??? if the refrig "POPPED" the outlet and surronding outlets sounds like you have a direct short within the refrig somewhere. no real quick fix for sucha thing other thtn physically checking all components looking for where hte trouble occourred
Mar 20, 2008 | Refrigerators
Hitachi Ultravision 53"- went blank
If it popped, it may have done one of 2 things, the convergence amps may have gone out, or there may be something in the horizontal output section that is shorted, either way call the repairman.
Jul 07, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Open Questions:
22 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
