I have no cooling. My thermastat has no display showing
  • 182 Answers
Check for power to the furnace.maybe a breaker or fuse?
Posted on Aug 11, 2008
98 dodge grand caravan overheating i checked whole cooling system
check thermastat sencer it is loctated on thermastat housing or block
Jan 21, 2012 | 1998 Dodge Grand Caravan
Hello sir/ma'am the heat (look like a heater) icon is appearing on the thermastat display beneath the temperature. how do i switch it to air and the snowflake icon to blow cool air. thanks for the...
look for the switch ..their should be HEAT-OFF-COOL the switch should be located next to these words ..you may have to remove a cover plate on the thermostat to switch to cool .you can find it ..let me know good luck..
Aug 25, 2010 | Heating & Cooling
Where is the thermostate located on a 1998 cadillac catera 3.0 v6 engine
Hi Friend:
To Locate your thermastat, Open your Hood and look down at the top of your radiator.You'll see a Top Raditor Hose that goes from your radiator to your Thermastat Housing.
You'll see a Hose clamp on the Thermastat housing .
NOTE: before you loosen the Hose Clamp Make sure you your car is cooled down and remove your radiator cap to release any pressure that is in your system.
After the Hose is off you'll see a Domed shaped Housing that is your Thermastat Housing. Remove the Bolts that Hold the Housing on and Seals the Cooling System.From Leaking out of the Housing.
After removing the Housing you'll see your Thermastat .Just remove it and Clean up all old gasket Material so you can replace the gasket with your new one .But put in your new thermastat 1st.
Then make sure you seal the gasket with Gasket Glue. And Replace the Housing Bolts and Tighten up good and Sung.
Put back on your hose then clamp.And Refill your Radiator with Coolant.
This will get your new thermastat in and get you Ready to go .
Thanks for using FixYa Please let me Know how my Solution helped you.By Voting .
Thanks Again From: d_hubbs
Aug 22, 2010 | 1998 Cadillac Catera
Beer is not chilling and the display keeps blinking
Let me know what you find out. I un plug the thermastate and it stops blinking. If I plug back in. It starts blinking again. Regardless with or with out it plugged in the unit will
not cool below 66 degree's. I think there isosomething wrong with
the cooling agent or the thermastat
Aug 08, 2010 | Krups BeerTender B95 Beverage Dispenser
1997 a4 se overheating.i have changed the thermostat and car is still overheating.cold air is coming from the blower.car drives perfectly otherwise.fan is not coming on.how would i diagnose the problem
Alot of time you have to bleed the cooling system after changing a thermostat it gets an air pocket in it look for a bleeder valve near or on the thermastat housing if so bleed it to get the air out.check the radiator and make sure its full because if you filled it up after changing the thermastat once the thermastat opened after the engine ran awhile well the cooling system needs refilled.
Mar 30, 2010 | 1998 Audi A4
Have a 97 catera, cooling fan is always running, thinking that it may be the thermastat. if it is, where is the thermastat located? heat is warm, not hot.
if the cooling fan is always running its a temp. sensor you will have to consult a repair manual to find the correct sensor
Jan 12, 2010 | 1997 Cadillac Catera
Fan works ok blows cool air thermastat is ok
This could be that the actuator that opens the door in the heater is dead.. or the actual heater-core is bad. Which is costly and expensive.
Oct 19, 2009 | 2003 Mitsubishi Galant
1995 toyota 4runner gets hot with new thermastat gasket
the thermostat should be closed when you take it out, therefore the thermostat is bad. It does not closed.
May 22, 2009 | 1995 Toyota 4Runner
Car overheats when when not moving
Sounds like you need a new thermastat. Relatively cheep and easy to intsall. Thermastat triggers your cooling fan relay.
May 16, 2009 | 1999 Honda Civic
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
