Question about Panasonic Televison & Video
My DVD player won't play i'm getting a code HO2 on the display screen. ModeL # DVD-RV31
  • BOSTON360 Aug 11, 2008
    This problem is with a DVD player not a projection TV.
    First its a " Panasonic Model #DVD-RV31" I used it yesterday everything was fine I did not shut it off. I used the pause button insted and never got back to it. Today when I started it up it would play. I got a display # HO2 insted
    Thanx
    Kevin
    I'm going to remove the cover, And take a look Keep my fingers crossed
    Thank You Very Much
    Kevin
    Genius:
  • 1,689 Answers
This is what i got from Josh Smith Online, this work-around requires opening the appliance, so before you start and follow this, please check on the warranty status of the unit.
error HO2 which more or less means the unit is shot. The problem centers round a spindle issue that is a known design flaw. Basically what happens is that the spindle gets warm, expands, and is then pushing on the top of the player .
You can see the tray which rotates with the DVD in. To fix this HO2 error I first had to start the spin by pushing the dvd counterclockwise gently. After that the DVD player would work but only without the cover on. This is the solution for now, though I plan to modify the case some in order to use the cover again. For now the DVD player slides into our entertainment stand and hides the fact that the cover is missing.
Posted on Aug 11, 2008
    Sergeant:
    Champion:
  • 248 Answers
It would need for this player to get to a repair shop however it is not advisable that you still get it repaired it would cost you as much as a new player...there are support available but again you would be spending as much as 2-3 new cheaper players..
    Master:
  • 521 Answers
The spindle motor is defective for sure check it out.
  • 6,487 Answers
You can try doing this remove the top of the unit, place a disk in the unit press play and gently give the DVD a gentle push in a clockwise direction.
This disk should then get up to speed and start playing. It also unlocks the error.
This is a solution by expert bmwrider before and it work for the other client before you may want to try that..
Good luck.....
  • Mark Gil
    Mark Gil Aug 11, 2008
    Did you follow the steps that I provided you to resolve this problem?? if not yet try that one and hopefully it will fix the problem...
  • 928 Answers
An HO2 error is either a problem with the optical pickup or a spindle. This means that there is something stuck near the optical pickup. It is possible to fix this by shaking the unit although I would advise against that. It would be best if you take the unit in for repair although you can open the device and check the lens and spindle are for anything that might have stuck.
    Master:
  • 623 Answers
Code HO2 means that your player is sensitive to scratches on cd's or dvd's so they won't play
  • ritchie dempacco
    ritchie dempacco Aug 11, 2008
    error code HO2> laser sensitve to scratches
    try a new cd with no scratches
  • Panasonic Master
  • 13,433 Answers
IS the dvd player covered by warranty?
ho2 seems to be a problem with the disk motor that spins the disk, its not spining.
  • Ekse Aug 11, 2008
    another expert on this website has suggested a possible fix to this:
    IF YOUR DEVICE IS COVERED BY WARRANTY DONT OPEN IT contact your dealer instead for repairs or replacement.
    Remove the top of the unit, be carefull not to touch things, touching the wrong thing can give you a shock. After you have removed the top, place a disk in the unit press play and gently give the dvd a gentle push in a clockwise direction.
    The disk should then get up to speed and start playing and clear the error code.
    Basicly the motor is either faulty or 'stuck' you need to give it a little spin. if that doesn't work you will most likely have to get it replaced.
    Credits to BMWRider for poiting out what the problem.
    Genius:
  • 1,056 Answers
You listed the TV, what kind of DVD player?
And...
Did it work before, and it stopped working?
Did you just hook it up, and it has never worked?
Have any other components been changed recently?
Does it do it with all disks in the DVD or just one of them?
The plaver will not play says HO2
1) Dirty or poor pick-up.
2) Sled motor sticking (bad sled motor or contaminated lubricant on the sled rails).
3) Faulty spindle motor. (especially if spindle motor is spinning with top off and no disc inserted).
DVD-RV31 also tends to suffer from dry joints to the surface mount IC's and that could cause all sorts of erratic operation.
Feb 03, 2010 | Panasonic DVD-RV31 DVD Player
After i insert DVD it reads then say HO2 then STOP= how do i fix this
You will need to get a can of the compressed air or use an air compressor if you have one. Then remove the housing cover if you can and use the compressed air to blow out any dust and debris inside the unit. Also blow air into the inside of the dvd tray. This has been the common fix for the HO2 error on your DVD player. You could also use a DVD lens cleaning kit.
Nov 02, 2009 | Panasonic DVD-RV31 DVD Player
Panasonic DVD-RV31 DVD Player plays black & white only (no color)
Hi,make sure your tv channel says av2 and not av2s as this will play in b/w,hope this helps
Jul 10, 2009 | Panasonic DVD-RV31 DVD Player
Panasonic DVD Player RV-31
spring motor bad need replaced
Manufacturer Panasonic Part Number RXQ0745 Description MOTOR Sub RXQ1218KIT
Dec 27, 2008 | Panasonic DVD-RV31 DVD Player
Panasonic DVD RV31 does not read DVDs created by Windows Movie Maker
The only thing that has worked for me is to make a copy of the disk after burning it in Movie maker.
Cordell
Jul 06, 2008 | Panasonic DVD-RV31 DVD Player
Region free code for dvd-rv31
all you need to do is use the DVD Service Disc that you got when you bought your DVD player,, or  go to www.panasonic.com and e-mail them about getting the codes removed so you can play overseas DVD, they sent me a disk for FREE and guess what it worked,,,, it comes with the instructions, here is what it says,,,
INSERT DISK- and confirm "STOP" is displayed...
USING THE REMOTE press "SETUP"
Go to "DISPLAY" menu
Select "ON SCREEN MESSAGES" then press "ENTER" button
Press ">10" found on the bottom right coner
Press "6" button
Press "4" button
Press "3" button
Press "8" button
A PASSWORD WINDOW SHOULD APPEAR
TYPE IN "3192"
PRESS THE "ENTER" BUTTON TWICE
the disk will be read, when finished remove disk
Oct 15, 2007 | Panasonic DVD-RV31 DVD Player
Televison & Video Logo
78 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
