Question about Canon PIXMA MP830 All-In-One InkJet Printer
RE: ink cartridge jammed
I put the black ink cartridge 8 in the 5 spot.  Now it is stuck.  Any suggestions on how to remove it besides beating it with a bat???
I took it in to the the store where i bought it and they removed it for me.
Posted on Aug 12, 2008
SOURCE:
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Cartridge Jammed in Canon MP520
Gently lift it out by pulling it toward you. Lift it up.
May 18, 2017 | Canon MP520 All-In-One InkJet Photo...
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
HP 22 color ink cartridge was put in cradle for HP 21 black ink
sounds like it is stuck ... suggestion is pull as hard as you can danger is you might break the cradle in the scoket ...
this issue can not be resolved via remote and someone with some
strength is needed
Apr 04, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Carriage jam on HP Officejet J5780 All-in-One
We have several of these in our company and the most common "Carriage Jam" cause is a glob of black ink in the bay on the right side. Once glob is removed, and "Carriage Jam" message appears again, press OK, and it prints fine from then on. Today the black ink glob was flat on top. Watch out for leaky cartridges, as the design of the particular HP device provides a nice catch pan for the tri-color ink cartridge, but not for the black one, so a leaky cartridge, besides being expensive and wasteful, can goop up the bay causing the carriage jam error message to try to get you to take a closer look.
Jan 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Canon Printer Picms MP450 Error 6500
They don't like re used cartridges.
I would purchase a new printer as they are not economic to repair.
Feb 27, 2017 | Canon Pixma MP450 All-In-One InkJet...
HP Officejet 7210 All-in-One Leaking Ink
the ink collector(well) hav accumulated much ink overtime its due to be serviced.remove the cartridges move the carriage to the middle remove the ink collector pad and clean , clean the collector with methylspirit check for the sensor beside and clean if blocked
Apr 26, 2008 | HP Officejet 7210 All-In-One InkJet...
Canon MP830 ink cartridge jammed
try to push the power button for about 5seconds before releasing...
Feb 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
83 people viewed this question
Clive
Clive
old marine
old marine
Ekse
