Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Defective ice maker dispenser
I have a Galaxy side by side refrigerator freezer, model 10656502400.  That's the number inside the refrigerator side.  The trap door thing doesn't close all the way causing air to get inside the freezer itself and makes LOTS of frost over everything.  I've tried taping it shut, but would like to find the parts necessary to repair it.
  • 2 more comments
  • mpgrantham Aug 12, 2008
    The solution was a link to a site where I could order parts. It did not list any Galaxy refreigerator-freezers, and I do not even know what part I need in order to make the "trap door" close all the way.
  • mpgrantham Aug 13, 2008
    None of the 3 solutions I have received answered my questions at all.  I'm sorry I subscribed to this service because it seems that you are not knowledgable about ice maker repairs at all.
    Nope...that isn't it. I've already tried that. I even got a hair dryer and melted any ice that might be in the dispenser or in places that I couldn't see. I have tried everything you suggested and have finally called an appliance repairman who says that is a common problem and usually requires the spring or other parts to be replaced.  He is coming today and will certainly charge a lot more than I paid you; so I'm sorry your solutions didn't work.
    I must not be explaining my problem clearly.  There is NO ice build up and even with the ice compartment completely out of the refrigerator and hot air from a hair dryer blown into all areas of the door, the flap just does not close.  The rerpairman I'm going to have to pay a fortune to come said there's probably a broken spring inside the door.  I'll let you know what he says for sure so that you can give that solution to others who have this problem.  In the meantime, remove me from your site because my problem is taking up too much of your time.  I'd like my money refunded also, as you offered.
    Thanks
    Guru:
  • 1,894 Answers
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues.
If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
Posted on Aug 12, 2008
    Master:
  • 623 Answers
Try cleaning rubberseal thoroughly...if it does not work..replace it!
  • ritchie dempacco
    ritchie dempacco Aug 13, 2008
    cgi.ebay.com/New-9010-FILTER-Refrigerators-Kenmore-Whirlpool-Kitchen_W0QQitemZ220260564519QQcmdZViewItem?..
    Master:
  • 521 Answers
Www.repairclinic.com
here is the link to get the required parts.
Posted on Aug 11, 2008
  • tech expert12 Aug 11, 2008
    dont forget to rate the solution sir
  • tech expert12 Aug 13, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
Siemens Refrigerator model KA58NA70NE The ice maker section is not working. Please advice how to fix it.
I had the same problem and fixed it by changing freezer fan found underneath the freezer inside body, just behind the ice delivery/crusher motor. You need to open all the inside upper components like ice dispenser, ice maker, ice crusher motor, lamps assembly and finally the rear upper inside body cover. First, check whether or not the fan has strong air ventilation before trying to change the ice maker fan motor.
Feb 04, 2011 | Siemens KA62DV50GB Side by Side...
My ice maker makes ice in my side by side refrigerator but the door on the dispenser sticks and won't open..... the ice then falls out when you open the freezer... any thoughts?
You have a solenoid actuator that opens that door electrically. Sounds like it is rusted shut or the coil is defective. would need to have your model number to tell you the part numbers. Thanks Sea Breeze
Dec 16, 2009 | Refrigerators
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water will not flow into ice maker
This could be 2 reasons for this The water control valve on back for the ice maker is defective or the thermostat inside the ice maker is defective. You can pore water into an empty ice maker and let it freeze. If it cycles and does not refill with water I would say that the water control valve is defective. Your refrigerator has 2 dual water control valves one is for the water filter assembly the one on the back is part number 61005626
Let me know what you find, Thanks sea Breeze click link below and enter model or part number in search feature.
http://servicepartstec.blogspot.com/
May 27, 2009 | Maytag MSD2756GES Side by Side...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water flow to ice maker
Two possible answers on this one. The water control valve for the ice maker is defective or the switches inside the front of ice maker are stuck.
Please send the model number listed for your refrigerator so I can help you find the ice maker switches and parts break down for your refrigerator. Below is my website address.
Let me know if I can help you more, Thanks Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
189 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
