Question about Ovens
Delonghi oven esm 495 st not working
The bottom oven will not switch on it fuses the main,however the top oven/grill does work
5 Suggested Answers
SOURCE: I need an instruction manual for Delonghi Proline ESM-465 ST oven
Try http://www.espares.co.uk/datastore/ProductManuals/356312.pdf
That's where I found it. Not easy to find though.
If you need to go direct to the espares website you'll have to hunt around a bit. But try looking out for a small Adobe link on the left hand side when in the ESM465 area.
Hope that helps.
Posted on Dec 22, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
barkencoa
  • 3463 Answers
SOURCE: Delonghi oven grill broken, oven still works?
You will probably find it is the grill element that is faulty, a common fault on your brand of oven, to be certain, you need a meter to test it.
Please rate my solution.
Thanks.
Posted on Jul 19, 2009
  • 195 Answers
SOURCE: My Delonghi EST461 ST oven has stopped working. The grill and fan work but the oven does not, it initially tripped the fuse. Any suggestions
always turn the power off first , you will need a flash light look carefully around the bottom element , I think it has burned out on you , it will have a bump or burned spot on it or may even be broken off , this is bery easy to replace and cheep if you find it is burned or broken off email all info on oven make, model, serial number I will locate the part and tell you how to replace it Have a nice day !
Posted on Dec 06, 2011
Hi my delonghi double oven keeps tripping the electric power supply it trips on the top oven when using the grill and the bottom oven on oven
I would have a electrician look at the breaker switch as being in need of replacement. They do weaken over time and cannot handle the load that they were designed to carry when brand new.
May 13, 2016 | DeLonghi Ovens
Dec 06, 2011 | Ovens
How to clean the grill element in an electric oven, it smokes everytime i use it
have same problem with grill smoking,try barry coates method if this works to stop from happening again there should be a tray that comes with most ovens,flip this over and put on top rack,should stop this problem,then place foil on bottom of oven to catch any spills or buy another tray.. all the best tony gilchrist....
Jun 22, 2010 | DeLonghi Ovens
Thanks.
Jul 15, 2009 | DeLonghi Ovens
Bottom oven not working
Jan 14, 2009 | Baumatic B904SS Stainless Steel Electric...
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Hope that helps.
Dec 01, 2008 | Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Ovens Logo
206 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
